Question about HP Pavilion dv6000z Notebook
My laptop not being able to boot from hard disk
  • Chris Hingee
    Chris Hingee May 11, 2010
    Does the BIOS detect the hard disk or can the BIOS run a hard disk diagnistic?
What is the boot disc and how do i install it
If the Windows operating system is installed on your hard disk then the boot disk disk is your hard disk. If your computer cannot find the boot disk then the hard disk maybe faulty.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 14, 2012 | Acer Computers & Internet
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
Jun 07, 2011 | Computers & Internet
My HP 4710s had a weird message that pops up after the logo screen. Then it says non disk or disk error strike any key to continue...I do that and the same message pops up...plz help.
the HP cannot boot up because it cannot find the hard disk to boot up from.
You could have a faulty hard drive or the hard drive needs re-seating.
If the HP still does not boot up after re-seating the hard drive go into the BIOS setting and see if the hard disk is detected. If not the most likely the hard disk is faulty.
To get the laptop working again. replace the hard disk, install Windows on the new hard disk plus the HP Laptop's device drivers and your programs.
Mar 20, 2011 | HP Computers & Internet
My laptop wont start up, It says "system disc or non system disc error, replace and press any key.." why? :(
you have it set to boot from cd so when you startup the computer it attempts to read the cd and than boot an operating system for you either remove the disk or enter your bios menu and set your boot order to negate the cd drive
Oct 25, 2010 | Computers & Internet
My laptop does not boot. it always ask for a cd to boot but i already reformat it.someone told me that it is a hard disk problem and advice me to replace my hard drive.
When the computer starts it flashes up press f2or delete or some other key to enter setup. Go through the settings and there should be one that will allow you to change the boot device. It sounds to me like it is set to boot from the cd rom drive only. Change it to boot from the hard drive and save changes to CMOS and restart the computer. The computer should now boot from the hard drive.
Aug 01, 2010 | Compaq Computers & Internet
How to boot from external hard disk plsss help
You could setup a dual boot system, this requires a fairly large hard disk and you need installation XP and Vista CDs.
The other option is to install XP only on your hard disk.
Mar 07, 2009 | Dell Studio 15 Laptop
USB booting of external hard disk in HP laptop
You cannot boot Server 2003 from an external USB Hard Drive, it will have to be installed on an internal hard drive.
Dec 05, 2008 | Computers & Internet
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
Got a laptop (ei systems) that i cannot properly start up, and access vital information which i just cant lose (court stuff etc). When computer turns on it say Boot device Hard Disk C / ...
try to boot your laptop from hard disk
reset your laptop & press f2 or del to go in cmos setup by press f2 or del key then afer go in boot manu select there is hard disk in a frist boot divice then save the settings by press f10
try this
may your problem will solves
Mar 23, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
186 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
