Question about Ovens
Frigidaire gallery series oven
Oven d broiler quit working but cook top still does is there a fuse somewhere
  • 2,478 Answers
Check your bottom element with ohm meter.
Posted on Oct 10, 2013
  • 61 Answers
SOURCE: cannot unlock oven frigidaire electrolux gallery series
Hello, what to do is to start another self clean cycle let the unit clean for about 3 minutes then push the cancel button.This should unlock the door if not a tech will have to come to advance the lock motor . good luck
Posted on Dec 21, 2008
  • 659 Answers
SOURCE: I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
http://www.frigidaire.com/support/manuals.asp
Posted on Mar 21, 2009
  • 30 Answers
SOURCE: Display not working nor oven frigidaire gallery
needs a new control. Easy to replace.
Posted on Oct 23, 2009
SOURCE: GE True Temp Oven not heating. Broiler works
we bought a new oven
Posted on Dec 15, 2009
SOURCE: Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Posted on May 31, 2010
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire PLEB30S8CCA baking element not working
Good Morning Jane, thank you for your post!
From what you have described, it sounds like you possibly have problem with a faulty thermal fuse, power supply board, user interface board or a communication error with the EOC (Electronic Oven Control). This is not a typical do it yourself job. Please reach out to an expert technician to ensure the appropriate replacement part(s) is ordered and is installed correctly to prevent future issues.
Best regards!
Feb 10, 2014 | Frigidaire 30 in. Electric Gallery Series...
Oven burner and broiler burner don't warm at all. Stove top burners work. Clock display normal. When turned on lights indicate oven on and preheating (normal). I have reset the main circuit breaker with no...
Hi Brian, thank you for your post!
Sounds like the either both bake and broiler element may be faulty or a potential wiring failure to the elements. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Sep 15, 2013 | Frigidaire 30 in. Electric Gallery Series...
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
Oven not heating
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Jun 22, 2009 | Frigidaire 30 in. Electric Gallery Series...
CPES389AC3 - Frigidaire Gallery Oven - Element and broiler
The element has blown in the oven you will need to fit a new one,and possibly the broiler one as well.
Plz rate this solution.Thanks.
Dec 20, 2008 | Frigidaire FEB30S5DC Electric Single Oven
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
50 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
