Question about Smoothfitness Exercise & Fitness
I have a Smoothfitness 5.65 and the speed readout kicke to EO1 and the machine stops
    Top Expert:
  • Smoothfitness Master
  • 12,223 Answers
Please read this steps and fix it. see the diagram attached. God bless you
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.I have a Smoothfitness 5.65 and the speed readout - e0ce916a-e304-4e53-8fb8-a0843b056ce9.gif
Posted on Oct 11, 2013
What does e01 mean on ninja 3 in one cooking system
EO1" occurs when the unit is still on but the pot has been removed from the cooking housing system. Place the pot back in the cooking unit.
This can also occur for the following reasons:
-if there is food jammed in the gap between the disc and the surrounding heating plate (the blade circle).
-if there is food stuck to the bottom of the pot.
-if there is food stuck on the heating plate (yes even a grain of rice can be a problem!)
-there is mechanical damage to the unit (disc is defective for instance).
-if the handles on the pot got bent down (so the pot is not fully seated on the heating plate and disc does not get pressed)
-debris or other damage preventing the pot from make full contact with the heating plate.
A good tip is to plug in the unit and turned to any mode. Please be sure the unit is completely dry. Use your finger to fully press on the disc and see if EO1 goes way. If pressing down does not clear EO1, then unit is defective.
If EO1 does clear by finger but does not clear when pot is installed - and bottom of pot, heating element and gap between the disk and heating plate are clear, then the unit is defective.
Dec 29, 2016 | Washing Machines
Speed Queen Model RWM274W-3062 top loader.Stops spin cycle after about 20 sec.When i open and close door it spins again for about 20 sec then stops. What could be the problem, thanks
Washing machines kick off when they're out of balance, like if something is too heavy and waterlogged on one side. Redistribute the laundry and it will be fine.
Mar 09, 2016 | Speed Queen Washing Machines
Treadclimber centering
Dear Sir:
ecalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the TreadClimber by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 15, 2012 | Exercise & Fitness
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
Need wiring diagram for a smooth 5.45 treadmill
http://www.smoothfitness.com/support/product-manuals.htm
GO TO THE WEB PAGE FROM SMOOTHFITNESS SECTION PRODUCTS MANUAL, GIVE YOU MODEL, SERIAL NUMBER AND DOWNLOAD FREE IN PDF FORMAT. AND READY.
GOOD LUCK.
SINCERELY.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Oct 08, 2011 | Smoothfitness Smooth 5.45 Folding...
A/c compressor kicks on but no blower motor in a/c mode defrost or heater
If this is electronic system with digital readout, it is likely the control head or blower motor speed controller. I think your owner manual tells you how to self test control head. go to car-part.com to find used part. or tascafordparts.com for new at discount.
Sep 20, 2011 | 1998 Lincoln Mark VIII
My 2003 955i Daytona speedometer was working fine, last night, the readout just started showing ''0'' regardless of speed. Is there a sensor disconnected/broken and where is that located?
The speed sensor is located in the front wheel. Follow the cable down to the axle. Please post the solution or problem if your figure this out. I been ride for a year now with the same problem. I've not had the time to check out the problem yet myself.
Aug 01, 2009 | 2003 Triumph Daytona 955i
My 5160 overheats during long hd operations (virus scans, backup etc). I have noticed that the fan is not kicking up to the top speed. diagnostics shows the fan dual speeds work as does the thermistor....
You can download a free software GUI fan control and set the fan speed to max all the time. this should keep your system running smooth and cool. You can even monitor it with a digital temp readout near the clock after you install this simple little program.
Here's the link: http://www.diefer.de/i8kfan/
good luck
tony
Jun 08, 2009 | Dell Inspiron 5160 Notebook
Smoothfitness 7.1hr would not run
Sounds like the motor is stuck or bad. Get into the front panel near the roller and remove that cover and check it with a volt meter
May 16, 2009 | Smoothfitness Smooth 5.45 Folding...
Exercise & Fitness Logo
80 people viewed this question
Top Smoothfitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Smoothfitness Exercise and Fitnes Expert? Answer questions, earn points and help others
