Question about Garden
Remove carburetor I have a TORO Personal Pace. Engine GTS 6.0 HP. Model 20023, Name: R-21S. Can you help me on how to remove the carburetor? Thanks
  • Ivan
    Ivan Oct 14, 2013
    After reading comments from other readers, I concluded that cleaning/replacing the carburetor may solve the problem. The problem that I have is the mower stops after a few minutes and restart again after a few minutes.
  • 38 Answers
Go to u tube and see if will show u
Posted on Oct 14, 2013
Testimonial: "I have checked u tube but found no video on how to remove the carburetor on my lawn mower. U tube has video on the 6.5 HP which is different than the 6.0 HP I own."
  • 67 Answers
SOURCE: How do you replace the belt
this is not easy you have to turn the mower on its side <make sure the carb is down > take off the blade belt guide and look at it the space is really tight and you have to hold the trans with two fingers and then walk the belt on. its hard because the trans is spring loaded to twist backwards to keep the belt tight
Posted on Sep 01, 2009
  • 630 Answers
SOURCE: i have a toro personal pace gts self propelled.
You can buy the whole part...cord,handle,recoil spring all in one piece and remove the old install the new...or you can just buy a legth of pull cord and swap everything over.
First take off the top 4 phillip screws and remove the plastic cover....don't forget to pull off the oil fill cap, next drill out the center of the three pop rivets that hold the recoil spring in place, use a drill bit a little smaller than the rivet, next tap the rivet out using a punch and a hammer, next install the pull chord by first rewindind the coil spring then locking it oin place so it wont twist back and install the new line(pull cord)...next install it on the top of the motor and install 3 new 1/4" aluminumn pop rivets 3/8" long with a pop rivet gun all can be purchased atb Ace Hardware...reinstall the reverse of dismantle proceedure and happy mowing...don't forget to attach the black plastic/rubber pull cord handle.
Happy Mowing!!
Posted on Jul 22, 2010
wentlanv
  • 710 Answers
SOURCE: model 20076 , serial# 270002127 2007
Hi gsrs,
Did you check all down the cable and see if the cable is in good shape, not stretched or frayed and connected at both ends where it should be?
Here is a website with a schematic that might help you: http://www.ereplacementparts.com/toro-20076-2700000012709999992007-lawn-mower-parts-c-121776_127291_127767.html
Choose picture I at the site.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on Apr 18, 2011
aquaman987
  • 927 Answers
SOURCE: I need to replace the pull string on my toro
If I'm not mistaken, I had one like this once. I think when you purchase the new one, it comes with screws. You have to drill out the rivets to replace the recoil assembly. Try calling to purchase a new assembly and question them.
Gary
Posted on Jun 08, 2011
bobntina
  • 29 Answers
SOURCE: How do I change the oil on my Toro Personal Pace
The oil drain plug should be under the deck. You probably have a bracket in the way that you need to remove. Once you remove the bracket you should be able to access the drain plug. Piece of advice do not cross thread the drain plug and do not over tighten it. You should only turn the drain plug 1/2 a wrench turn above finger tight.
Posted on Jun 15, 2011
My Toro Personal Pace mower will not come up to normal full idle.
If this is a Briggs and stratton engine, there should be a screw that holds the carburetor bowl. Remove that screw and look for a hole that runs through the middle of the screw from side to side just above the treads. Clean with a thin wire or maybe a paper clip. Then clean the perpendicular hole in the screw that runs from top to bottom. Reassemble and attempt to run. In my experience, if you don't have success at this point, you can buy a new carburetor on amazon for about $20. Install and your good to go.
Good luck to you!
Ben.
Apr 03, 2017 | Toro Garden
Engine starts after primer bulb is pressed 5 or 6 times, but dies after running a few seconds.
Main jet in carb is clogged. Also check the fuel lines to carb and make sure that they are intact and have no leaks.
Jul 29, 2016 | Toro Recycler 22" 149cc Personal Pace Lawn...
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro 22" personal pace with key start. Just
Pull the air cleaner of to see if fuel is getting to carburetor. If it is then see if its getting fire to the plug by taking out and put the wire back on but be careful not to hold the wire or the plug if fire is week then get a new plug or get a new one and see it that helps
Jan 25, 2011 | Toro Lawn Mower With Toro Power Tools
I have a Toro Personal Pace Recycler mower with a 6.0 hp GTS engine. I need help on replacing the pull cord.
It's not that hard. I've never done it on my Toro GTS 5.0, but I have done it on a Briggs and it's pretty much the same. Start by removing the 10mm bolts around the perimeter of the engine shroud. DON'T remove the 4 top bolts on the recoil housing. You might have to remove the fuel tank first. Drain it, then loosen the 2 8mm screws and lift it straight up. No need to disconnect the fuel line, just set the tank aside. After removing the 10mm bolts, the shroud should lift right off. Flip it over and you will see the recoil pulley. Remove any leftover cord from the pulley. Now you need to wind the pulley against the spring in the direction it goes when you pull the cord. It might wind 2 or 3 revolutions but don't overdo it. Now you will need some sort of clamp to hold the pulley in place as you line up the slot in the pulley with the opening where the handle goes. Next, feed the new cord through the opening and into the pulley and tie a knot to keep it from slipping out. Carefully release the clamp and let the pulley slowly wind the new cord onto itself. Finally, attach the handle on the other end of the cord and test it. If you can pull the handle and the cord comes out and it retracts normally, re-install the shroud and tank.
Oct 02, 2010 | Toro Lawn Mower With Toro Power Tools
Change oil in TORO GTS personal pace
warm engine remove dipstick place drain pan on floor tip mower on side so dipstick tube is over pan
Aug 14, 2010 | Toro Lawn Mower With Toro Power Tools
Totr model #20479 GTS 5 motor, when you push prime
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Nov 16, 2009 | Toro Lawn Mower With Toro Power Tools
I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
