Question about Ricoh Office Equipment & Supplies
Ricoh aficio mp 4002 says offline but it's turned on
spinal
  • 287 Answers
SOURCE: ricoh aficio mp 2510
Hello e3tech, faatmaan has given you some valuable and accurate information. I would like to offer you some additional information that may help. i am not sure to what degree you have technical experience regarding problems as deep as you are experiencing. I just want to try to help you starting with the basics. We can get the proton accelerator out as a last resort. :-) In the event you have not tried to reset the code (which you can in the event that this code was a temporary condition or erroneous to start with) let me walk you thru the process of resetting the code and lets see if the copier can recover without going into the ugly (but prehaps necessary) and expensive stuff. Again I am just trying to help and this is the first thing anyone should do. We need to enter service mode, usually accessed by the expensive on site technician but you can handle it. This is the first thing I would do if I was onsite. I have been working on copiers for 20 years, which may merely mean I have been on a reign of terroe for that long, screwing everything up! LOL .Ok in order to enter sevice mode on your machine you will need to press the yellow button marked "clear modes" then then numbers 1-0-7 in slow but firm sequence, and the the orange stop clear button and hold IT down tull the screen changes and you will hear a beep. Once again......Clear modes,then 1>0>7 (in sequence) then hold down the orange stop/clear button till the screen changes and you hear a beep. (note....the beep is not guaranteed as it can be turen off prior to what we are doing but you will see the screen change). the new screen may say a number of things but for sure it will have a block named copier. Press that block which will bring up another new screen with all kinds of stuff that you need not be concerned with.The fact that you are at this screen is the cool thing. At this point, turn the main power swith off....!!!!!! THE ONE NEXT TO YOUR LEFT KNEE!!!!!! not the one on the op panel. Unplugging the copier will do the same if you are unsure.The point is to totally de-energize the copier. Turn the copier back on, and this point it will know that some one who knows what they are doing it attempting to help it recover andthe copier will wake up witha new outlook on life and will try to successfully restart back to normal. Without the steps we just went through the copier would have not went through the servicr mode process required foe it to truly have a chance to recover. When you turn it back on, the copier will look at all the critical sub systems it monitors before it feels comfortable to say "READY". In this case the errer code has to do with the very high temperature area called the fuser. As you probably understand, the manufacturer of the copier has designed the copier to keep close tabs on this area as to not burn down your building. So id there is any oddity in this area the machine throws a temper tantrum. So, lets hope hope the machine restarts, and it was a temporary thing , and you wont have to go the route that faatmaan suggested, which again may be absolutely accurate and well detailed. I just thought we could try the reset and hope for the best as it is a genuine and viable option and alot less expensive. I wish you the best. By the way, in the future, ALL error codes you get in the future(and there..are a hell of alot of them) can be reset in the manner I described ealier.This can be a big help for you . It just so happens that this and a few others in the "500" series are less likely to stay reset. I hope I have helped save you alarge wad of cash, but a minimum you are armed with a few valuable tools that may save you buttocks in the future. Take care.................. SPINAL
Posted on Feb 19, 2008
Joed911
  • 4338 Answers
SOURCE: i need ricoh aficio mp 1600le driver, how do i get into.
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 11, 2008
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
  • 126 Answers
SOURCE: where is waste toner bottle
waste toner bottle is just beside paper tray 1. its the left side small cover. open the front cover and open the screw from top and open the cover in front and pull the bottle out. if its hard then email me on ronils_singh@yahoo.com.au. i am a Ricoh tech. i will help you out.
Posted on Oct 01, 2010
  • 23 Answers
SOURCE: how do i factory reset a ricoh aficio mp 2000?
what is the setings u want to reset ?
Posted on Feb 03, 2011
How do i reset ricoh aficio mp 2000
Need for information on problem but try main switch turn off wait 30 seconds then turn on
Oct 21, 2015 | Ricoh Aficio Mp 2000l Copier / Printer /...
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
Please help. My printer is Aficio Rico and the number is MP 2500. It indicates it is offline.
Check the connection to the printer. Check the ports on the driver to see if it's using the IP port or USB. Otherwise the IP's on the network changed.
Jun 22, 2014 | Ricoh Aficio Office Equipment & Supplies
I have a Ricoh Aficio MP 161 that was given me to use at work, I am on a construction site, and we don't have internet access, so I had to borrow a Verison Access card... anyway I have tried to install...
What was the driver that was installed? Where did you get? Are you sure that was installed the PCL6 for Ricoh Aficio MP 161?
I think your problem is with the driver. You can download for free the driver on the page of Ricoh.com.
You have a good equipment. I have much experience in this model. Reply any question ok!!!???
Feb 08, 2011 | Ricoh Aficio MP 161 Black and White Copier
Ricoh Aficio 2020 All-In-One - printer offline
Under printer check book unmark Use printer offline
Nov 23, 2009 | Ricoh Aficio 2020 All-In-One Laser Printer
Adding developer to the new ricoh aficio mp 1500
Apr 10, 2009 | Ricoh Aficio 2015 Copier
283 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
