Question about Velocity Micro Cruz Reader R101 Tablet PC
My Cruz will not turn on and the reset button doesn't help but the green light is on
Info on a cruz TABLET t301 need to reseT AND NOW IT DONT COME ON
Cruz™ ' Support FAQ
www.cruzreader.com/Cruz_Howto.php
How do I factory reset my Cruz? ... What should I do if my Cruz Reader (R100 Series) will not turn on? ... Why does the headset audio sound strange on my T301? ... How do I connect to the Internet if I don't have Wi-Fi at home? ... through CruzTablet.com or one of our Official Retailers come with a One-year Limited Warranty ...
How to unlock my cruz tablet t301 - Cruz™ Tablets
www.cruzreader.com/Cruz_Model.php
How do I connect to the Internet if I don't have Wi-Fi at home? How do I remove an ... How can I unlock my R100 or T301 if I forgot the pattern? How does storage ...
Amazon.com: Questions And Answers: Cruz won't turn on...what do I do?
www.amazon.com/Cruz-wont-turn-what/.../1?asin...
Amazon.com, Inc.Jun 19, 2011 - Velocity Micro T301 Cruz 7-Inch Android 2.0 Tablet (Black) ... Caity, Idon't know if this will solve your problem, too, but my ... Everything seems to be working just fine now. .... you have to is reset it and hold the power at the same time until comes back hold it for ... Worked perfectly, thanks for sharing the info!
How to Master Reset a Cruz Tablet ' Chron.com
Jan 19, 2016 | Velocity Micro Black Cruz T301 2gb Wi-fi...
My cruz wont turn on after i reset it?
Most tablets are still in the factory settings so if u have a professional to look at it he might be able to turn it on and u could then have him look at the charge thing.
Jan 20, 2014 | Velocity Micro Cruz Reader R101 Tablet PC
When turning n the cruz tablet, the word cruz pops up and goes away. then cruz flashes
First don't worry too much you're just stuck in a loop or have bad firmware (most likely). The fix is probably going to be easy but you have to do some things. Just follow the directions I give and that Velocity gives and you should have no problems in about half an hour.
Take out the top SD card. Put in in your computer or an adapter that goes to the computer.
Go to the cruz website and download the current firmware (http://cruzsupport.velocitymicro.com/ics/support/KBAnswer.asp?questionID=814).
Even if you have updated the ROM something could have happened and it could be corrupted so replace it. Put that firmware on your sd card. Do not extract the zip file. Do not change its name. If the name changed (like if it has (01) at the end) delete the old file you downloaded and change the new one back to the old name.
Eject your sd card when you finish and put it in your tablet.
Press the top power button and the up volume button at the same time. Continue holding. You will see cruz but dont stop.. it'll flash kinda and it'll still say cruz.. keep effin' holdin'...
the robot shows up: you win! let go relax give it some time to freshen up. Have a cup of coffee and let it finish. Everything will be tidy and new when it's done.
the robot doesn't show up and the same thing that's been happening happens again: try pressing reset when it turns on (paper clip in that hole youll feel a button when you get it right). Keep pressing it the whole time it has power to try and get a hard reset. Do it like 2 or 3 starts and fails just for good measure.
then try to flash again (power and volume up).
if that doesn't work pull the back, unplug the battery and wait 30 seconds to a minute. plug it back in and try flashing the first time you start up. like don't press power hoping its going to turn on now. It won't. You have given it a clear quick access memory which may let you get to the point where you can flash without failing.
IMPORTANT: On the first time after the battery is plugged in hold power and up volume together and keep holding. This is important. If you press power it will recurrupt the RAM and you made the back lose and unplugged the battery for nothing.
If that doesn't work.. well it should. You're stuck in a loop that you should be able to pull out of. Go back the the beginning and make sure you have the new file you downloaded and the name is correct (its on the cruz support website).
If that's all done properly try the battery thing one more time. If it's still failing don't give up.. give it hell. I was stuck in a bad one going strait to white screen only being able to shut it off by pulling the battery and I was able to get it to flash (took about 30 tries). For the trying at this point you don't have to pull the battery just keep starting it with power and volume up pressed.
As long as you're not staring at a black screen you should be able to fix this.
Good-luck!
Dec 07, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Cruz reader t301 will not turn on
I plug my tablet in all I get is the red light on the bottom
I have a cruz t301 can you help me
thank you
john
Nov 16, 2011 | Tablets & eReaders
My Android Cruz Reader R101 starts on the Cruz flash screen, skips then goes back to Cruz flash screen. I have reset it using the reset between the power and External SD card. I also removed the back and...
This sounds similar to something that happened when I tried rooting my android phone. If it's the same thing, that means you will need to go to recovery mode and install an update.zip package that you can find somewhere online for it. It's because the code for what's supposed to happen after that screen is overwritten and it doesn't know where to go.
May 06, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
How do I do a hard reset on the Cruz T301 Tablet?
Hi.
Press reset hole button using a paperclip, then hold down volume + button until 'Cruz' appears on display. That will reset the tablet.
Apr 29, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
My Cruz reader will not turn on. It froze and shut off. I've pressed the "reset" button but it still won't work.
My mom's did the same thing. Try holding in the reset button and the power button at the same time for 25 - 30 seconds. release them both when you see the Cruz boot screen appear. It should be fine after that
Jan 15, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Won't turn on - I hit the power button on my Velocity Cruz micro reader to make it 'sleep', but not it won't come back on at all ... what can I do to make it turn on?
Usually when you have what i would call a power lock out. you must remove the battery and wait a few minutes and put it back in, and it usually fires up. Most electronics have these problems. If you are 100% sure the unit is charged with a green light, or no light at all, and you pressing of the top button does not turn it on then remove the back, it is very easy. You can lift it up with your fingernail. If new and faint of heart, under warranty, and all, then make that phone call. Otherwise, you must attempt to remove the connects to the big grey squared battery for a moment, which is said to be easy to do and the battery easy to replace. Look for instruction on the removal on YouTube, or other sites. However, I am more than sure this will solve the problem, unless it has been in liquid, a power surge, dropped, or in excessive heat or cold, or touched by some with "bad karma" for electronics (just kidding). hope this helps.
Jan 02, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
I turned the Cruz Reader off and I can not get it to turn back on. I tried to charge it but no light will come on. Any suggestions?
Taken from Velocity Micro Support Center:
What should I do if my Cruz device will not turn on?
If your Cruz device will not turn on or freezes, follow the steps below to resolve this:
  • Locate the Cruz RESET location between the Power Button and mini-USB port.
  • Using the straightened end of a small paperclip, insert it perpendicularly into the RESET hole and hold for 5 seconds.
  • Turn on your Cruz
If the steps above do not allow you to power on again, then continue with the steps below:
  • Remove the Cruz from the charger and eject the External SD card.
  • Place the Cruz face down on the desk, starting at the External SD slot, pull off the back cover of your Cruz.
  • In the lower left corner of the back of your Cruz, locate the battery power cable. Unplug the cable and replug it again.
  • Return the back cover to your Cruz and snap it into place.
  • Re-insert your External SD card and power on your Cruz.
Velocity Micro Cruz Reader R101 Tablet PC Logo
20 people viewed this question
Top Velocity Tablets & eReaders Experts
 Mikey
Mikey
deton8 von Splosion
Are you a Velocity Tablet and eReader Expert? Answer questions, earn points and help others
