Question about Audio Technica ATH-ANC27 Headphones
Left Ear cup not working.
Right is fine and left is out
These headphones have a TERRIBLE switch. The power switch on the left earcup activates two microswitches in the earcup - each side has it's own noise cancelling circuitry. The switch for your left earcup is failing. I've already had one set of these replaced, and after a month of use my replacement pair is starting to have the same issue. The microswitches are really small, so fixing yourself is unlikely.
Posted on Jun 17, 2015
  • 25 Answers
Either ship them back to manufacturer if still under waranty or you'll have to re-solder the wiring to that speaker if they have become disconnected or yanked accidentally of which the leftside is usually where the headphone cable first enters in the left side.
Posted on Oct 15, 2013
Why no more sound in left side? the right side is fine. i moved the left side like a seesaw, then i found where the sound occur. is it the wire connection problem inside the left side? what to do?
Opened up one of the earcups and dont ask me how it was just by force. The cable that connects the 2.5 to the speaker is frail and there is quite a bit of shielded cable that can rub against each other over time. I fixed it by removing the cable and soldering in two separate cables of similar size.
Apr 21, 2016 | SOL Republic Master Tracks MFI...
Soul by ludacris left ear cup problem
BEst to just try to find a repair shop for that sort of thing. Disecting headphones is a risky venture, and 9/10 it results in a frustrated, headphoneless user.
Jan 30, 2014 | SOUL by Ludacris Bolt Signature Series...
Need to repair a cut wire going from the left ear cup to the right ear cup
In fact the insulated inner wire (the white tube) is the signal carrying wire.
The outer wires without insulation are connecting ground (GND).
Both wires have to be connected to the speaker in the ear piece in order to (re-) build a circuit.
Jul 12, 2017 | Audio Technica ATH-A900 Professional...
Beats studio no bass working in the left cup.....
There may be a broken wire or defective connection in the left side.
Mar 28, 2017 | Beats By Dr Dre Studio Noise-Canceling...
How do I install batteries.
remove the ear cushion from the earcup, twist counter clockwise a quater turn untill u overcome a slight resistance and lift off, underneath u will see 2 batteries one either side of the driver.(i think it is the right one both cushions are removable anyway. The batteries should be NiMH rechargeable not standard AA do not use AA .the batteries recharge when u put the headphones back on the cradle takes about 18 hrs
u can use a external charger which is probably quicker. There is built in overcharging protection so this should not be a problem.
Sep 02, 2009 | Audio Players & Recorders
How do you disassembly right side headset to fix faulty connection
The headphone unit is sealed and cannot be accessed via the padded ear pads. You have to prise open the outer headphone cover which breaks off 4 internal attachment points (which can be re glued for re assembly). Be careful on the Left hearphone as it contains a complex electronic circuit board.
Aug 01, 2009 | Jabra C820s Headphones
How to install bobbin
In the shuttle area there is a silver round piece- called the shuttle race cover. It has a black ear on the right and a black ear on the left. Push the right ear to the right, and the left ear to the left and the silver ring should come out. Behind the silver ring is the bobbin case stuck in the hook. Remove that, jiggle it, move it, just work the bobbin case out of the hook. Now put the hook back in the machine. In the machine there is a driver that looks like a half moon. Your hook looks like a half moon- make a full circle out of both of them. Re-install the race cover, pushing the left ear to the right and the right ear to the left to secure the race cover, and your problem should be solved.
Jul 07, 2009 | Necchi Sewing Machines
Both cans keep cutting out
Check the 1/4' stereo phone plug for broken wires if you can unscrew the shield. If that is not the problem, you will need to replace the plug and the cable up to the left can. I say left because there is another cable from the top of the left can to the right can carrying the right signal. You said left was mostly cutting out so that connecting cable is likely fine. Slip the foam ear pad off the left can and see if there are screws holding the speaker plate to the cup. Inside of the cup there should be a place where the main cord meets up with the other cord. Make note of the connections and the colors of the wires. You should be able to save the cable grommet by cutting the cable close to it and pulling the wiring out of the insulator and then peeling the insulator tubing out. The rest is parts, soldering and careful, patient work. Remember to solder in a ventilated area.
May 03, 2009 | Sennheiser Audio Players & Recorders
A Bose headset is buzzing
The speaker in that Ear Cup may be blown. You should consider replacing the set with a newer one.
If you listen to this with that static noise you risk serious injury to your ear.
Jan 04, 2009 | Radio Communications
Audio Technica ATH-ANC27 Headphones Logo
503 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
