Question about Xerox Phaser 8500/DN Printer
Cannon mg 3122 paper jam ... I was printing and it printed like 3 copys then when it went to print the next copy it grabbed like 1/4" stack of paper and it jammed up... cannot get to the paper from either end... what do I do
  • 2072 Answers
SOURCE: rx tray full remove paper
That is an easy one.
Look into the area where the paper comes out. You have to look toward the upper rear area rear area. There is a white plastic flag, about 2 inches wide and 1 inch in height.
On each side of it you will see 2 areas where the shaft snaps into, that flag has popped out of those clips and is not seeing the sensor making the machine think there is a piece of paper in the output tray.
Reach in and gently maneuver that back into position and carefully snap it back into place.
That is an odd shaped actuator you can't see, but with some patience you can snap it back into place. Maybe also gently take a pair of needle nose pliers and slightly tighten those clips that it snaps into. I suggest that with a lot of concern so that you do not snap the plastic clips, they are part of the frame that if broken would be expensive to replace. Use your discretion as to whether they need to be tightened. If it snaps back in and feels solid DO NOT try to tighten them please.
Posted on Jan 03, 2008
SOURCE: LSU error message
dear sir,
please printer for lsu problem
Posted on Jun 18, 2009
  • 17 Answers
SOURCE: repeated paper jams
These errors are usually caused by a cracked DM Camshaft (Drum Maintenance). This was a very common problem for Xerox, they usually broke while under warranty, but there a heck of a lot out there that are just now going bad after a year.
You may or may not need to replace the "Motor Process Drive Gears" as well as the DM camshaft.
You might be able to talk Xerox into doing this as a warranty repair, if you ***** real loud.
Posted on Aug 21, 2009
  • 118 Answers
SOURCE: Xerox 4150 continues to jam on first print - "print engine jam"
Chances are you have a buildup of toner on the charge corotron. This is a part of the copier that charges the drum to accept toner. If there's buildup of toner inside or on the grid of the corotron then the charge will be erratic or excessive and cause the paper to jam as it passes by the drum.
Check your user manual on how to properly remove and clean/replace the corotron.
diyurself28
  • 20 Answers
SOURCE: xerox phaser 8560 says "paper jam - open front
try cleaning the microswitches. it may also have a sensor and if the little plastic piece that crosses between them has broken off it will throw codes. mine is ok so i cant say for sure but you can try to glue a suitable piece in there to trick the printer if thats the case or bypass the sensor. just a few suggestions from my experience with electronics
sensor is kind of this: gap is where the plastic part is supposed to go in between.
Posted on Oct 24, 2011
Cannon d1320 false paper jam
this happens due to overheating of the fuser unit.try resetting it
Jan 25, 2014 | Canon Imageclass D1320, Copy, Print, Scan...
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    When I went to run the copy machine this morning it jammed. The paper jammed where it grabs the paper. I removed the drawer and got the paper out. Put the drawer back in the machine and it was fine. I...
    This could be a faulty sensor, but as a no cost option it could also be a worn pickup roller.. just try to roughen it with some sandpaper... see if that helps..
    Apr 19, 2017 | Canon imageRUNNER 210S Copier
    Hello paper jam error appears with no paper jammed. Then printer refuses to print or doesn't print well
    To resolve paper jam issue, follow the steps
    1. Open the rear access door.
    2. Remove any bits of paper stuck.
    3. Clean the rollers using lint free cloth ( upward position )
    4. Close the rear access door
    5. Open the front panel door
    6. Check for any paper stuck between the rollers.
    After doing all these steps, to make sure if your printer is working fine, try to make a copy.
    If the printer can make copy, Click on the link to resolve printing issue -> Link
    Oct 12, 2010 | HP Photosmart 2575 All-In-One InkJet...
    My Kodak esp 3200 won't print labels on Avery label pages. WILL print the labels on regular copy paper. Any suggestions on what to do?
    I am having the same problem except you didn't address the problem. It's not that the printer prints badly, jams or crashes. The printer literally passes the label paper through the printer and then prints on the next piece of copy paper. I reset my printer not to print the last page first and it still did it. Then I put the label paper second in the feeder. It passed through the first piece of copy paper and the
    labels and printed on the third. It's like the printer senses the thicker paper and skips it. My printer is a Kodak ESP C315 and I have no setting for thick paper only plain and photopapers.
    Sep 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Double sided copying
    http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
    here is the manual p4 and p16 discuss the topic:
    Duplex printing 1
    The supplied printer driver supports duplex printing.
    Guidelines for printing on both sides of the paper 1
    �� If the paper is thin, it may wrinkle.
    �� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
    Slot.
    �� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
    stack.
    �� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
    If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
    Improving the print quality in the User’s Guide.
    Manual duplex printing 1
    The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
    instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
    or you may get a paper jam. Very thin or thick paper is not recommended.
    Simultaneous scanning, printing and faxing 1
    Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
    document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
    is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
    copying or fax receiving has finished.
    �� Manual Duplex
    Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
    printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
    numbered pages are printed. There are six types of manual duplex binding directions available for each
    orientation.
    �� Booklet Printing
    When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
    middle.
    �� Binding Offset
    If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
    May 14, 2009 | Brother MFC-7440N Laser Printer
    Paper feed grabs more than one sheet
    Try fanning your paper several times. Take that nice neat pile of paper in your hands and wiggle it so that your thumb fans through the edge of the whole stack. Do this on both edges so that the stack of paper is slightly less perfect. You can also gently fold the whole stack slightly in both directions. Do this every time you add fresh paper. It should only take a few seconds.
    Apr 21, 2009 | HP Hewlett Packard Officejet Pro L7680...
    G85 series prints crooked
    From HP's site:
    Problem: The print on the paper is skewed.
    Solutions: 1. Slide the paper-width adjuster against the left side of the paper stack, and 2. make sure that the rear access door in the back is fully “locked”.
    Jun 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
    Lexmark 5250 printer
    Before you put papers in tray it must reshaple make separate each other , to delete the message "off the power " on again to continue printing.
    Dec 10, 2007 | Lexmark X5150 All-In-One InkJet Printer
    Printer and Making Copies does not work!
    Will the machine run a paper path test?
    This sounds like it could be a sensor indicating a paper jam, if this is the case, it won't run anything through the paper path (not even a blank page).
    Nov 26, 2007 | Sharp UX-B20 Plain Paper Inkjet Fax
    Xerox Phaser  8500/DN Printer Logo
    47 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    CheckitRight
    CheckitRight
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
