Question about Proform EKG Tread Drive Motor Model Number PCTL53590
Proform EKG PCTL53590 does not start the motor. I press all the play button and the treadmill will not start.
    Top Expert:
  • Proform Master
  • 12,223 Answers
See the video attached and proceed and fix it. God bless you
Posted on Oct 11, 2013
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
bubathebear
  • 3 Answers
SOURCE: Treadmill Speeds Up Automatically
you might have it on a preset workout....i would read the instructions and find out how to put it on manual
Posted on May 20, 2009
erpaalai
  • 999 Answers
SOURCE: My Proform treadmill will not incline. It is stuck
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Posted on Jun 17, 2009
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
roadtech7
  • 297 Answers
SOURCE: Describe your proform 765 ekg
The problem you have is one of two things. 1 you have a loose walk belt, or 2 you have a spun front drive pully.
You need to remove the front cover to be able to observe the drive belt as it is turning on the drive pully( on the LH side of the front roller) try to stop the walk belt while traveling at speed setting 3. Hang on to the side handles, if the drive belt runs as normal, watch the front roller it will be slipping. If this happens you will need to replace the front roller.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 05, 2010
Treadmill willnot run
Check motor....if motor ok check the controller
Jan 03, 2014 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
My Treadmill PROFORM 760 EKG will just stop as I am walking on it.
see the video and proceed according. Lube the rollers front and rear, test the drive belt motor and replace.
God bless you
Jun 16, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
My Proform 770 EKG treadmill's motor is overheating. What is the voltage that should be pulled during use? Should the walking belt be replaced if we replace the motor?
see the video and lube correctly. 2) go to my personal TIPS for motor help.3) however you must see the voltage in the plate of motor. the tolerance will be +- 10% of voltage. can be voltage continuosly or alternating voltage.God bless you6527db9f-a9f8-47a6-9208-af2b680ea3a0.jpg
Apr 01, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
I have a proform 765 ekg and just replaced the motor because the treadmill kept stopping but it still stops and the breaker kicks off and the motor is real hot. any thoughts on why it still stops
LUBE the deck belt and rollers bearing this happen to due the lack of maintenance. see the video attached. Do it with silicone or wax read your manual.
If after you did lube the problem remain, TIME to replace the old board deck belt.
God bless you
Feb 16, 2013 | Proform Quick Burn Pro Treadmill with 12...
Bought a proform ekg treadmill from a lady on line
Mine did the same thing. I had to take the display apart and clean the contacts on the circuitboard that are underneath the buttons. After I put it back together it has worked perfectly. Mone came from a house where the people smoked and it was the nicotine and tar that was in the smoke that had seeped inside and cause it to stop functioning properly. Well I guess thats why they sold it to me. They likely were not using it anyway. Well I hope this helps
Mar 13, 2010 | Proform 730 Folding Treadmill Model...
I have a Proform 770 EKG Treadmill jerks and squeaks
The drive belt was loose. I tightened up the motor just a smidge using a crow bar. That solved the problem.
Dec 29, 2009 | Exercise & Fitness
Proform 765 EKG
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor. www.AtlantaFitnessRepair.com
Aug 10, 2009 | Proform Sport 1000 Folding Treadmill...
Treadmill LED Track does not go to start with key inserted
I pulled the safety switch out, and the elevation is stuck on 10 degrees
May 14, 2009 | Proform 775 Crosstrainer Treadmill - Free...
Proform EKG Tread Drive Motor Model Number PCTL53590 Logo
119 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
