Question about Coby MP620 MP3 Player
Battery dies even if it is turned off - Coby MP620 MP3 Player
I have a video nikko page call badder dan dem by raga-z
Posted on Oct 11, 2013
Hi my 91 subaru legacy was going jujst fine and then all of the sudden while i was pushing on the pedal , the car just stopped moving and died. and wont start back up. wont even turn over.
Hi Reese, what do you mean by "won't turn over"? Does the engine rotate but not fire, or does it not even rotate? If it won't rotate, perhaps your alternator belt was loose or worn and the battery didn't get charged. If the battery is good and the engine rotates, then the alternator has possibly died. The other possibility, is that the fuel pump had died.
Feb 05, 2014 | 1991 Subaru Legacy
92 ford ranger wont start
how old is the battery get it checked and make sure the connections at the the battery and the terminal on the stsrter pos. post are tight. find the grd term on the engine and make sure every thing is good and tight
Dec 17, 2012 | 1992 Ford Ranger
Battery dies every other day. Bought new one and now it wont even wont turn over
have you checked the alternator. so when you put in the new battery you get nothing . thar is the alternator. my link to my garage https://www.facebook.com/TedsRepairs
Nov 15, 2012 | 1991 Jaguar XJ6
My jeep won't start or even turn over
you need to check the voltage at the battery when you have trouble. should always remain above 12 volts.
If not then the battery or the connections are bad. first test the battery right at it's lug terminals, then check the terminal connectors. battery or cable or connectors - def sounds like major voltage issue in the battery area!
Mar 27, 2017 | 1994 Jeep Wrangler
Wont start
Try using another battery or assisted battery connected from another vechile as batteries just die. If the battery is malfunctioning then the error messages are shown.
Jul 25, 2012 | Chrysler 300C Cars & Trucks
When driving the radio died then the car died wouldnt start again wont even turn over
It sounds like your alternator went bad. The alternator is responsible for keeping your battery charged and at full power. If it goes bad, your battery eventually drains and things start to shut down.
Get your alternator and battery tested, I'm sure you'll find the alternator has died.
Oct 19, 2010 | 1994 Nissan Altima
Just bought a new battery and put it on and the car wouldnt even turn over but when i jump it it would start right up but then die 5 mins later
you need to charge the battery and also your charging system it shld not die because the alternator will take over to supply power to the system if it is charging even though the battery is still weak
Jan 21, 2010 | 1991 Dodge Stealth
1999 Pontiac Sunfire won't even turn over, but the
The radio will work even with a dying or discharged battery.
First, be sure to check all of your fuses in the engine compartment.
A full battery will keep the headlights bright with the engine off. With a dying or discharged battery, the headlights will be noticeably dim.
When you turn the key to crank the engine, does the starter try to turn or make a fast clicking? If so, the battery if low or dying. If it makes a slow click then stops, then it's REALLY dying.
If you don't have a battery charger, go to Walmart and get some jumper cables. Hook up a friend's car to yours. If it starts, then the battery was low, either from a bad battery or a bad alternator.
If it doesn't, you have electrical problems, possibly a bad starter or starter solenoid.
Jun 30, 2009 | 2005 Pontiac Sunfire
Car died wont start
maybe you should have the battery cheked and all the cables and the soliodes
May 21, 2009 | Oldsmobile Delta 88 Cars & Trucks
Turned key and starter turned over until battery died
This sounds like the sylinoid is bad. Di you check it.
May 18, 2009 | 1997 Honda Accord
Coby MP620 MP3 Player Logo
15 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
