Question about GE JBP15 Electric Kitchen Range
Ge model JB968TOH1WW Back of oven is hotter than front
2 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: ge oven not sure the model it is 12yrs old
Check all connections to control board. If all check ok then replace control board.
Posted on Nov 16, 2007
The oven runs too hot...even at lower temps
If the oven is in temp runaway and just gets hotter and hotter, always on, then there is a failed component. If the temp is just somewhat hotter but is still being controlled then there is a user temp offset procedure to calibrate the oven temp. See your user manual. If a failed component it can be several things from a oven temp probe to the oven controller. There are electrical checks to determine which including reading the resistance of the temp probe at a known oven temp and checking this with a oven probe temp vs resistance chart.
Dec 31, 2013 | GE Spacemaker JMP28 Electric Kitchen Range
Oven is hotter in the back of the over than the
Good Afternoon Essie, thank you for your post!
So I understand you're staying that the oven has a higher temperature in the front, is that correct? If so, technically speaking that is very rare or not possible. I suggest to make sure the pan is placed in the middle of the rack and not closer to the front or back. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you!
Nov 03, 2013 | Frigidaire 30 in. Electric Gallery Series...
We have a GE XL 44. The oven won't heat up at
sounds like a bad control panel , I bet it is a touch button type if it is get all the info off unit and order control panel here http://www.appliancepartspros.com/
Jul 27, 2011 | GE Ovens
I believe my oven igniter is bad in my GE Profile XL44 Stove. How do I go about replacing it myself?
On most GE models: Remove oven bottom by removing two screws at very back of oven floor, lifting up back side of floor, pulling back a bit to disengage front of oven floor, and remove. Next, remove flame spreader, allowing you to see burner and igniter. It is easiest to remove the burner assembly to change out the igniter.
Mar 13, 2011 | GE Kitchen Ranges
My GE Monogram oven model #ZET 1SOL1SS The preheat of 100 never goes off and the oven gets much hotter than the temp I have set.
I am having the exact same problem with my ZET 1SOL1SS Monogram oven.
I would be greatly appreciative if you could post what the solution ended up being for you.
I really can't afford to pay hundreds of dollars for a service call right now.
Thanks in advance for your help.
Oct 28, 2010 | Kitchen Ranges
Hi..if i set the control knob to 350 for the oven..its goes to 400 or 450 degress..i put a oven termonater in there..its always hotter than what u set it on. model # JBP24G0K2AD or the o is a 0 not sure..
The oven thermostst needs replacing, as it is not sensing the correct temperature, this is the switch behind the control knob
Please rate my solution.
Thanks.
Nov 10, 2009 | GE Ovens
Oven hotter at the back
You should always preheat oven to operating temperature before cooking anything.
Do not put too much in oven, leave plenty af space for good air circulation.
Do not place any reflective foil or the like on the bottom of oven or shelves, as this reflects heat, and you will get uneven cooking.
Make sure fan is working efficiently if it is fan assisted.
Dec 09, 2008 | Neff U1421 Double circotherm Electric Oven
Ge oven not sure the model it is 12yrs old
Nov 16, 2007 | GE JKP15 Electric Single Oven
GE JBP15 Electric Kitchen Range Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
