Question about Garden
I have a grasshopper 718k and the clutch(operating blades) will not engage.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Check for a blown fuse. then check for a bad pto switch and then check your circuit board ( i am leaning towards this )
Posted on Oct 20, 2013
4 Suggested Answers
  • 143 Answers
SOURCE: When I engage the blades the eletric clutch kills
Check the grassbox switch, it might be faulty
Posted on Jul 04, 2009
  • 138 Answers
SOURCE: engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Posted on Aug 24, 2009
  • 6468 Answers
SOURCE: mower blades will not turn on with pto switch engaged on john deere stx 46
first look for a blown fuse the old clutch may have burn it out the check to see if a safety switch burned out
Posted on Apr 02, 2012
Cutting blade won't engage
with unit off look under at deck and inspect cable and pulleys and belt adjust and or repair
Sep 28, 2016 | Garden
Husqvarna yth 170 problems when engage blades clutch nothng happens
On the 170 there is an electrical clutch that enables the blades to engage. This of course is an important safety feature.
If the operator is not sitting in the seat the switch located beneath the seat will not actuate. It is possible that the weight of the operator is insufficient to activate the switch. Other possibilities are the connection to the switch has become disengaged, or the switch has failed.
There are other possibilities of why the blades do not engage but I would evaluate the seat switch first and the relay (operator presence relay) that the seat switch activates second..
Nov 28, 2015 | Husqvarna Garden
Blades won't engage on my toro ss 5000 zero turn mower
for any ride on machine that the blades don't engage id start at looking at occupancy seat switch , these are most times the culprits then if that's ok I move on to the actual engage switch and then on to clutch as last element
don't forget that past 2013 mfg machines operator must be in seat and weight over 80 lbs , the clutch pedal must be depressed and transmission not in reverse to engage the blades on a consumer grade lawn tractor (thank the CSB for that )
Aug 27, 2015 | Toro Garden
Why mower blades will not engage when buttom is pulled
I believe this one has an electric clutch. Check to see that the switch is operating properly, that the wiring is good to the clutch, and that the clutch is good. Use a volt meter to check that there is voltage to the clutch when the switch is operated.
Jul 15, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Why won't the blades engage on my Ariens 911403
Chances are the deck drive belt has been knocked off one of the pulleys or the drive clutch won't engage properly. With the spark plug wire removed, rotate the blades by hand and make sure they both move together. This verifies the blade linking belt is OK. Now engage the blade operating control and feel for resistance as you rotate the blades. If you feel no change in resistance, remove the belt cover and reinstall the drive belt over the pulleys and tensioner/clutch mechanism.
May 31, 2014 | Ariens 34 In. Zoom Series Riding Mower
Battery losing charge
Sounds like you have defective diode rectifier. this little box when working properly allows your voltage to only go 1 way to charge the battery. if you have used a vehicle to boost the tractor you have damaged the rectifier. because a vehicle running puts out 14.8 volts lawn equipment is 12 volts only you can boost using a vehicle only if it is NOT running
Apr 04, 2014 | Garden
Scotts L2048 lawn tractor deck wont engage
You need to check the wires from the clutch, with the ignition on pull the pto switch out there should be a 12 volt supply at the wires if not replace the pto switch, if you have 12 volts then it is the clutch itself, they are not realy repairable, so may need a replacment.
Jul 16, 2013 | Garden
Mower dies when pto is engaged blades move freely
Could be the seat switch. Your operator present switch only comes into play when the clutch is engaged. If the drive clutch is engaged, and the pto is engaged, the operator present switch has to be moade.
Aug 03, 2010 | John Deere Garden
I have a Troy Bilt riding lawnmower(Big Red Horse) 23hp, when I engage the blades it draws the amps down below 12, and continually draws it down until the blades shut down. I have replaced the battery. It...
I'm guessing the blades operate from an electric clutch and you have a short related to the clutch. Check your switch, wiring and clutch for bare wires shorting to ground.
Jan 07, 2018 | Garden
Garden Logo
197 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
