Question about Valet Systems VDSLW Front Door Station , White Louvered
I WAS WORKING ON A VALET INTERCOM DOOR STATION. I CANNOT TALK OR HEAR ANYTHING AT THE FRONT DOOR STATION, SO I DISCONNECTED THE SPEAKER AND HOOKED UP A TELEPHONE TEST SET TO THE SPEAKER WIRES, WORKS FINE. THEN I INSTALLED A 45 OHM SPEAKER AND THAT DID NOT WORK. WHAT CAN BE THE PROBLEM?
  • Valet Systems Master
  • 16,181 Answers
45 OHM speaker? That is way too high.
Posted on May 30, 2014
The phone will flash with an incoming call but there is no ring
Turnot up your speakerphone volume. If that doesn't work then the speaker in that phone might be bad. Can you talk and hear over the intercom? If so the speaker is good
Sep 23, 2014 | Mitel 5220 IP Phone
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
We have DMC-10RS intercom system in our house. All them squeal when the power source is on. I had to unplug the hub to make them quiet. I cked the power supply and its putting out 12.2V,ok. Any ideas what...
Check power supply for proper voltage of 12 volts DC.
-If there are multiple Hubs, check voltage on all Hubs
If the voltage is not 12V, try replacing the power supply
226888 Power Supply
-If the voltage is ok, disconnect 1 room station at a time. If there a multiple Hubs, disconnect the last Hub. As each room station and/or door station is removed, have someone else listen to see if the squeal goes away. There is a chance that one bad room or door station is causing the issue.
oIf the squealing stops, add in the previous stations that had been disconnected. If all stations other than that room station are ok, do not hook up that station. There are no replacement stations available for this system. If the squealing continues with any of the stations hooked up, there is a bad HUB. DMC-10 Hubs are NLA and cannot be repaired. The best option for a replacement is the I2000 Kit
IntraSonic Intercom System Kits Quality Home Systems
Please visit our website if you have more questions.
Central Vacuum Intercom and Whole House Audio Systems
Don't forget to like and visit our Facebook page..
https://www.facebook.com/QualityHomeSystems/?ref=hl
Apr 25, 2014 | M&S DMC-10RS: Intercom Room Station
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
How do I change time and date on Toshiba DKT2020SD
Toshiba DKT2020 set work with a lot of different Toshiba systems. That being said this should get you in the right direction.
Date
  • From receptionist station, without lifting the handset, press "Intercom"
  • Dial "#651"
  • Dial the time in YY:MM:DD format.
  • Press "Redial" or "#".
  • Press speaker.
Time
  • Dial "#652"
  • Dial the time in military format HH:MM:SS.
  • Press speaker.
Day of the Week
  • Dial "#653"
  • Dial the day of the week (1-7).
  • Press speaker.
Nov 09, 2010 | Toshiba Lands Phones
Speaker phone problem
It is possible. I have ATT 945(?) 4 line phones that communicate via a DSL-like signal between units to do special things like intercom, etc.
What I have in my setup is that I have a seperate line from the point of entry of my phone line to my DSL modem.
I then have TWO stacked DSL filters PER LINE that feed the main phone line running to all the phones.
Be AWARE that when using the speaker phone there is a modulation of the gains both directions. When you talk OR have a noisy background noise, the gain of the speaker is cut down to prevent feedback. And when you go silent, the speaker gain is increased for you to hear the other side of the call. Essentially it takes as much discipline as the old two-way radios... one talker at a time with these speaker phones AND very little background noise.
Jan 09, 2010 | RCA 25425RE1 Phone
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Lee
Jun 17, 2008 | GE RCA 4-Line Speakerphone
Intercom
you can press the speaker button when the phone rings and you will talk over speaker. make sure the mic light is on so the caller can hear you.
Jun 02, 2008 | NEC DTU 8-1 Corded Phone
Valet Systems VDSLW Front Door Station , White Louvered Logo
98 people viewed this question
Top Valet Systems Home Experts
Donni Steen
Tom Chichester
Are you a Valet Systems Home Expert? Answer questions, earn points and help others
