Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Repair manual the washer will only run when the drying is on
Indesit iwde7168 fault code f01 on drying
Indesit F01 is a board/motor fault, as it is happening on dry I would suggest looking at the board again ensuring there are no other blown solders or indeed the repaired solder connecting to another
Apr 07, 2014 | Indesit IWDE7168 Washer Dryer - White
My washer/dryer isn't drying clothes
this is all i could find on the internet and that is the manual not sure if its going to be of any help to you but you could go to this link and download the manual and see if it does help you out.
i think its the first one on the page.
candy alise go4w464 washer dryer not drying clothes Google Search
Oct 31, 2017 | Candy Washing Machines
Washer will not spin clothes "dry".
Lgm0923, we're sorry to learn of the experience that you've encountered with your Washer. Have you tried the troubleshooting suggestions on page 5 of your User Guide? The link is below. https://www.whirlpool.com/content/dam/global/documents/200311/owners-manual-3955869-RevB.pdf
If further assistance is needed, please email us your name, address, contact number, model and serial number at Whirlpool_Reviews@Whirlpool.com.
Oct 24, 2017 | Whirlpool CAP2761K Top Load Washer
Wont dry clothes, i can turn it on and wait a second then open door and heat appears to be onbut it seems to take hours and hours to dry a load
You may have a blocked vent.
Remove the connecting vent from the rear of the dryer.
Run a load of laundry.
Use timed dry at 50 minutes if possible.
If it dries correctly clean and repair the exhaust vent.
Dec 26, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
I bought my LG Intellowasher WD-8016C second hand and have no manual. Does it need to be washed occasionally with washing sda. There is a bit of mould around the seal. How do I clean this.
Manual suggests Exterior with household detergent. Do not use methylated spirits, diluents or similar products.
For internal, dry around the washer door and run washer through a complete cycle using just hot water... and repeat if needed.
Not sure about mould.... not in manual.
Nov 02, 2009 | LG WD-16115FD Front Load Washer
Dryer Problem
EC4 The temperature of air vent
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
You need to call for repairs. Probably the heating element is faulty.
You can create a custom program without a dry cycle and hang dry your clothing.
Nov 21, 2008 | Haier HWD1000
Kenmore Dishwasher Control Lock
Hi tdowling,
I'm Harvey the Master Plumber.
Your problem is: The Control Lock randomly turns on and disables washer from running. Holding down the Air Dry option key for four seconds as instructed has no effect. When this doesn't happen, the dishwasher works fine.
When a d/w has this kind of random problem it means either a bad control board or a loose connection on the control board. I don't recomend this kind of repair to the average homeowner. You could try the Repair Directory for a repairman. Also, if the d/w has a few years on it you you might want to consider the costs or repair verses replacement. The randomness of the problem makes it frustrating to run down.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Kenmore Dishwashers
Equator EZ 2512 CEE Front Load dryer not starting
The blinks are the fault code on the unit you will have to watch them an count match them to the chart in the service manual
Here is a link to the service manual
http://www.appliancedesk.com/appliancedesk/service/CWD/EZ3612CEE_EZ2512CEE_EZ1612V/Service_Manual.pdf
Feb 20, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Drying
When yr washer does not rinse, it could be that your outlet is clogged. Ensure that yr outlet filter is free from any kind of blockage. Check this, it is a small door in front of the machine bottom. Plug off the wall & clean out, expect some water to come out when you open it. If this is not the case check out your outlet pump. Try reading your manual throughly; it surely helps.
Sep 29, 2007 | Malber WD1000 Front Load Washer/Dryer
Dishes and inside the washer are not drying
Make sure that the drain hose is connected as per manufacturer instructions, and that there isn't a direct run down from the sink u-bend to the machine. The rinse agent effects dishes dry but has nothing with the water remaining in the machine. Good luck!
Sep 15, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
