Question about 1997 Saturn SL2 Tie Rod End Replacement - OE Replacement, Front, Driver Or Passenger Side And Outer
Engine dies I recently changed the fuel filter to the Saturn car. thinking this would resolve the situation, the car continues to have problems. It has 143989 miles on it. It starts fine, but when I turn off the engine, it'll have trouble cranking, even stepping on the gas doesn't help. it'll start for a second, then die again. Any Idea on what the problem may be?
    Problem Solver:
  • 8 Answers
Sounds like the timing might be too advanced..
Posted on Oct 11, 2013
89 chevy s10 misfires and sputters when i give it gas, dies when i stop. Sometimes it runs fine, but recently it's just been bad. When i rev the engine it can stabilize the idle, but usually die
check fuel pump pressure- fuel filter --air filter --egr valve if carboned up clean or replace and cat converter feel the exhaust if feels restricted may be clogging up
Mar 30, 2013 | Chevrolet Blazer Cars & Trucks
I am having a few issues with my 1992 Saturn... One I think the Fuel filter needs to be replaced, Where is this fuel filter located? Sometimes my key will not come out after turning engine off, I have to...
Whom ever told you that the Saturn's where hard to find parts for it is wrong. I used to own a 1992 Saturn SL1, and had no problem finding parts at the local Autozone or Napa stores.
I believe that your fuel filter is either located on the frame rail just under between the drivers and rear seats; or possibly under the hood in-line just before the fuel rails/ injectors. I wish I would have never gotten rid of mine, it was a great little car.
Aug 30, 2011 | 1992 Saturn SL1
My Saturn L300 (2003) starts sometimes and doesnt others. when it does start sometimes it will just die. i have replaced the fuel pump, fuel filter,crank sensor and the transmission control module. my...
If it starts up easily when the engine is cold and has a hard time starting (or won't start) when the engine is warm a lot of times it's related to the ground cable(s). If the problem is related to the security system I would think it would be an all or nothing kind of thing (ie. it wouldn't start and then die). Another thing to check would be your fuel pressure to see if it's actually staying at the correct pressure after the car starts.
Mar 22, 2011 | 2001 Saturn L-Series
Wont exceed 20 mph
does it idle fine but sputter and want to die as you continue to accelerate? Had that problem recently in a dakota. changed the fuel filter and it helped but then continued to do the same. replaced the fuel pump and fixed the problem.
Dec 22, 2010 | 1997 Dodge Caravan
How to change 2002 saturn L200 fuel filter?
L200 just change fuel filter but still runs like there is air in it i can run it fine for about 10 mins then it just dies please help
Nov 17, 2009 | 2001 Saturn L-Series
1996 Blazer w/V-6 Vortec dies at op-temp. will restart. ongoing
I WOULD STILL CHECK THE FUEL PRESSURE.IF ALL IS GOOD.ENGINE GETTING TOO HOT WILL SHUT OFF.ALSO A LEAKING INTAKE GASKET WILL CAUSE STALLING WHEN HOT.
Jul 26, 2009 | 1996 Chevrolet Blazer
Difficult to start
If you have not changed the fuel filter, that may be your problem. Try changing the fuel filter once a year to keep your fuel system clean and running right.
Hope this helps and good luck.
Apr 19, 2009 | Saturn SL2 Cars & Trucks
I have a 1992 saturn 4cylinder twin cam. the saturn will drive and then die . I will wait about 10 minutes, then i can restart car again drive and then die. I have replaced fuel filter and changed out fuel...
My 94 SW1 did the same thing, that is the same basic engine but a SOHC. I replaced the crank position sensor which is in the block behind the starter and the problem went away. There are most likely other problems which can cause stalling, vapor lock due to bad gas cap for one, but mine was fixed by replacing the sensor. Bit of problem getting to it, but you were already in the area when you replaced the fuel filter.
Apr 01, 2009 | 1992 Saturn SL
Dies out
did you run out of fuel proir to the problem? if so, then you may have sucked up some debris from the bottom of the petrol tank, change the fuel filter as i had the same problem. the way the fuel filter is situated next to the fuel pump if any debris goes thru the line when you stop the debris will block the line.
Aug 15, 2008 | 1992 Subaru SVX
1997 Saturn SL2 Tie Rod End Replacement - OE Replacement, Front, Driver Or Passenger Side And Outer Logo
71 people viewed this question
Top Replacement Tie Rod End Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Replacement Tie Rod End Vehicle Part and Accessory Expert? Answer questions, earn points and help others
