Question about Android Tablets & eReaders
My tablet will turn on but it wont go past the android screen what to do and how to fix the problem. please help
  • 44 Answers
I had this issue. Your firmware is corrupted. The only way to fix is to install Uberoid (latest version 12.1) which will bring your tablet back to life.
http://www.pandawillforum.com/showthread.php?15703-Universal-WM8650-Uberoid-v12-1-(CUSTOM-ROM)
Posted on Oct 25, 2013
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
  • 846 Answers
SOURCE: i dropped my android tablet
You can get the part at android Repair and there is a guide that shows you how to put in the part at tablet Repair Guide.
Posted on Apr 11, 2011
  • 3940 Answers
SOURCE: my binatone homesurf tablet is stuck on the home screen and wont do anything can you reset it
Sounds like it needs a reset.
The Binatone Helpline is available from 9.00 am to 5.00 pm, Mondays to Fridays, please call0845 345 9677 for UK+491805938802 for EuropeAustralia customer service number 1300 768 112 or email to service@shriro.com.au India customer service number +91 7503011385 or email to assist@binatonetelecom.in
http://www.binatonetelecom.com/binaries/content/assets/binatone/products/android-products/homesurf-7/pdf/homesurf_7user_guide.pdf
The manual has very limited troubleshooting, so it looks like you'll need to call them.
Posted on Oct 25, 2011
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
SOURCE: how do i unfreeze my android tablet
My Pandigital screen is frozen, all I get is a green android with a triangle with an explanation mark inside it. How do I reset this?
Posted on Nov 23, 2012
Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
Sep 30, 2016 | Tablets & eReaders
How do i fix my proscan tablet that is stuck on android screen
Try a power reset by pressing the power button for 30 seconds with your device unplugged, then plug in your device and leave it on the charger for a few minutes, then press the power button again for 30 seconds while plugged in.
My tablet won't turn on
Atonio, Check the attached troubleshooting links for tablets not turning on,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Do When Your Android Phone or Tablet Wont Turn On
Help My tablet won turn on what do do
my android tablet wont turn on how to fix
Why Does My Android Phone or Tablet Not Turn On
Jun 30, 2016 | Tablets & eReaders
How do i factory rezet my nobis tablet when its froze and wont go past the nobis emblem screen?
Hi Jeffrey, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
How To fix any Android Phone Tablet that won turn on
Apr 30, 2016 | Tablets & eReaders
Tablet wont turn on fully it freezes on the opening screen than just freezes there and wont turn on all the way what can i do to reset it
How to Fix a Frozen Samsung Galaxy Tablet [Solved] - Samsung ...
www.tomsguide.com/forum/id.../fix-frozen-samung-galaxy-tablet.html
2 days ago - 30 posts - ‎27 authors
I have a Samsung Galaxy Tablet that is completely frozen. ... If done correctly thescreen will turn black and automatically start the reboot process. ... Sure have, it won't turn off, swiping the front screen doesn't do anything. My Samsung tablet won't turn on! - Samsung - Android ...
Jan 17, 2016
My Samsung tablet will not turn on. - Samsung - Android ...
Dec 30, 2015
My RCA tablet won't turn on. What do I do? - Tablets ...
Dec 28, 2015
Help! My tablet won't turn on! what do I do?! - Asus ...
Apr 1, 2015
More results from www.tomsguide.com
Jan 21, 2016 | Tablets & eReaders
Maxwest tab-9155 won't load past android screen
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
please reply if it helped
Mar 24, 2014 | Tablets & eReaders
Android Tablet wont turn on.
CONNECT TO POWER SUPPLY .... PRESS ON BUTTON (20 SEC) THEN ... WITH OTHER HAND / FINGER KEEP TAPPING SCREEN .... REPEAT UNTIL TAB WAKES UP
Jul 22, 2013 | Google Android 4.0 7 inch 1080P Video...
Visual Land Connect Android 4.0 wont boot
Hold the power down and press the -volume button down to reboot
Sep 29, 2012 | Visual Land Connect Android 4.0 Internet...
Tablets & eReaders Logo
458 people viewed this question
Top Android Tablets & eReaders Experts
Phillip Whisenant
Phillip Whisenant
Lawrence Oravetz
Are you an Android Tablet and eReader Expert? Answer questions, earn points and help others
