Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel washer (IWL12) will not drain. There is also a burning smell. There is no water leaks. I removed pump motor. There are no burn marks and it spins freely. I looked at the motor controller on top of washer. There are no burn marks there. The diverter valve does not show any signs of burning.
  • 62 Answers
It could still be the pump (the coil/winding may have a short.
try it out of the washer to see if it spins.. most are just 2 wire AC 220v
Posted on Oct 16, 2013
  • 1550 Answers
SOURCE: Fisher Paykel GWL10US Washer won't spin
It looks like it has to be the control module.
You need to replace it .
It will cost you around $200 .
Posted on Oct 16, 2008
  • 22 Answers
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Posted on Oct 20, 2008
  • 22 Answers
SOURCE: Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Posted on Oct 21, 2008
SOURCE: Fisher Paykel GWL10US won't spin
hi
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
maryk2002
SOURCE: wont drain looked in pump area does nto appear to
After taking all apart and putting back together 3 times looking for some type of clog in the pump area I decided to take the hose off that is located underneath the washer. There I found a penny!
All better! I love my fisher paykel! I personally fixed it.....saved myself $95.00 per half hour and parts. Since i am a woman lots of times a repairman would have said I needed a new pump!
Posted on Jun 15, 2009
Fisher Paykel Intuitive Eco Washer IWL12 fault code 37
Pump Ohms to low will smell like burning enamal
The pump will need replacing,
Apr 06, 2013 | Fisher and Paykel Washing Machines
Tip
Mildew smell, gray streaks, won't drain, puddles on floor, burnt motor smell
I have had various issues with my fisher paykel top loader (GWL10US) and didn't realize they were all due to a plugged drain. I had mildew smell from excess water that never drained, gray streaks on clothes from dirt and residue that remained in tub, water left in tub and wet clothes after spin cycle, puddles on floor, and finally it wouldn't drain at all and the motor smelled hot/burned out.
This was all caused by a sock that got in between the outer/inner tub and went to the lowest part of the drain and finally blocked things so a leak was created and water dripped into the motor and caused a burn out.
To repair, bail water out of washer and unplug the washer. Tip machine back so you can see the motor/white plastic housing unit (pump) on bottom of washer. Where this unit attaches to the bottom of the washer, look for a clip/tab that you can pull with your finger (like a childproof cap) and twist the unit off the machine and unplug the connectors (there are 2). Once this unit is removed, you will see a quarter-sized hole into the bottom of the wash tub. this is where i found the elusive SOCK and pulled it through the hole.
When you order the "pump" it comes as one unit--motor and white plastic--and you twist it back onto the machine and plug in the connectors.
another website I've found helpful is ths.gardenweb.com/forum/laundry
on Oct 21, 2008 | Fisher and Paykel IWL12 Top Load Washer
Intermittent Draining and Burning Smell
The water will not run in the machine.It will for a few second then stops. What could be the problem?
Aug 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
Burning smell
Hi just read your posting.Now in my experience on your model of machine when you get a burning smell it is usually the pump.When the machine is draining the water and goes to spin do you get a burning smell then?Please try to look underneath the machine to the front right.You will should see the pump with a red or black fan attached to it.See if has any evidence of corrosion or leaking.Please reply with additional information and I can guide you throe rectifying this fault.
Jun 16, 2010 | Fisher and Paykel IWL12 Top Load Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher paykel washer that is not drain/spinning properly and I noticed a burning/hot smell. Anything i can do? It is 5 yrs old.
ours did the same thing with the burning smell also. I found that the pump motor kept tripping out from overheating and would not empty the drum thus telling the computer not to spin. I took out the pump and found that the rotor inside the armature had surface rust all around it so i gave it a light sand to clear the rust and whalah...no more tripping out, the pump motor needs to be disassembled to get at the rotor.
Mar 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Help
YOU NEED TO CHECK IF THERE IS NOTHING STUCK IN THE PUMP AS NOT DRAINING ALL THE WATER IS A SIGN THAT THE PUMP IS NOT DRAINING COMPLETLY.GOODLUCK. MOHAMED
Sep 18, 2008 | Fisher and Paykel IWL12 Top Load Washer
Broken washer
could be clogged drain. look at my issue "eco smart won't drain, smells hot" on how to remove motor from bottom of washer and check lower drainage area. bail water out first and be ready to catch water when you remove that motor unit.
May 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
119 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
