Question about Garden
Jd 133 will not start with key - Garden
  • 118 Answers
Hi tim, sounds like you have a safety hold you out or the small red wire is loose on the solonid. or you mighe put a load test on the battery, if all this checks out ok then make a ushape jumper wire and jump the two big posts on the solonid (but dont hold it to long it will get hot) if you hear the starter kick change the solonid. also be sure all conections are tight.
Posted on Oct 11, 2013
John deere srx 75 starting with key doesn't work why
if u wiggle the gear shift lever , holding key to start does it work ? if so then u need a new or adjustment neutral safety switch (also key does have running deere on it ?) as non factory keys don't work to well either
also this machine is listed on jd tech site as one that has been noted for an "starting improvement kit " part # - AM107421 jd has made it plain that they know it doenst start so well ,so they have released this kit to install that improves its starting
May 25, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My JD JS35 mower hit a stump and instantaneously stopped. It won't start. Occasionally it will fire once. What might be wrong?
Hi, it has most likely sheared the flywheel key and thrown the timing out. Also check that it has not bent the blade or crankshaft. Regards Phil.
Jun 27, 2012 | Garden
My uncle has a john deere 111 and my dad turned it on and off apparently trying to get the key out and it hasn't worked since. What should my uncle do?
Is this the old JD 111 made from 1979-1986? I would guess that it was left out in the weather over the years and that is why the key was stuck. Check the ignition switch and the starting solinoid. That is where I would start. Let me know if that is it. If it still does not work, then there are other routes to go. I have a JD 111 from 1980 that was recently left to me. I tuned it up last year and it still runs good. That is a testament to the old JD's.
Aug 17, 2011 | John Deere Garden
JD LT 133 removing 38"
Raise the mower off the floor then put the deck down on it's lowest settings. Hope that works.
Oct 18, 2017 | Sport & Outdoor - Others
Lwin brand jd-vd760 (invalid key)
sent back to mfg who not fix over phone.
Dec 21, 2009 | Jwin JD-VD765 Portable DVD Player
I have trouble starting my 316 JD tractor. When I
I do not have answer I will like to have an answer for my 316 JD no power no lights on dash battery new and was running shot off and wont stared again.Thank You
Aug 15, 2009 | John Deere New Tractor Starter w/ 317...
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
