i have formatted my machine then installed all the driver of printer but except scanner everything is working fine while scanning it gives the msg "cannot communicate with scanner.Cable may be disconnected or scanner may be turned off.Checked Status.Scanner driver will be closed.
Comments:
Sep 24, 2007
- pls guide me up i m in urgency
Sep 24, 2007
- NO CO-OPERATION FROM YOU TILL YET.
Sep 24, 2007
- i have formatted my machine then installed all the driver of printer but except scanner everything is working fine while scanning it gives the msg "cannot communicate with scanner.Cable may be disconnected or scanner may be turned off.Checked Status.Scanner driver will be closed.
-   I have exactly the same problem. It has been described by promod perfectly. What can I do?-   schumcat123
Oct 15, 2008
-   I am using MP 180 and when I turned on, the display shown " scanner error " and the alarm lamp and on/off lamp flash alternately. please help !!
-   doel93
May 12, 2008
-   no puedo scanear-   Guest
Mar 21, 2008
-   in LCD is blink error code E42 , how to this solution ??-   Guest
if you put the installation cd in the drive and then if it autostarts close it down, then go to device manager and the properties of the scanner and update driver let pc search automatically and it should reinstall it and then all should be fine i hope , had the same problem on my all in one device
Was this helpful?
Yes
No
Solution #2
posted on Jan 09, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem with my MP180, and it worked out when I tried a different USB port in my computer. I also read elsewhere that a good quality high speed USB cable would also eliminate this problem.
While scanning it gives the msg "cannot communicate with scanner.Cable may be disconnected or scanner may be turned off.Checked Status.Scanner driver will be closed.
hi, CANON PIXMA MP160 All-In-One InkJet
Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
Only the top half of the page prints, then the carriage slides and the rest of the page is nearly...
(More)
Only the top half of the page prints, then the carriage slides and the rest of the page is nearly blank.
Printer errror has occured. Turn off pwr then back on. Shows 6AOO at top. have tried over and over...
(More)
Printer errror has occured. Turn off pwr then back on. Shows 6AOO at top. have tried over and over pulling plug and reconnecting. Whats my problem??? John K jtksr@yahoo.com
Comment by Guest, posted on Feb 21, 2008
scannr error problem says that the scanner driver is not installed.
