Ir5065 jam 0103 - Office Equipment & Supplies
Canon ir5065 error E000400-00100 details
it is assumed that some spare parts are replaced designed for other country. ID MISMATCH BETWEEN DC CON AND LSU.
Thanks.
Dec 20, 2014 | Office Equipment & Supplies
Canon ir5065 Error detailsEooo4-oo400
sir
clr the error code in service mode. then check the the heater power supply (may be country mismatch). check the dc-con pcb.
thanks.
Canon ir5065 eror000808-0002
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermistor. Hope this helps...please post back for further assistance.
Aug 07, 2012 | Canon iR 5065 All-In-One Printer
Eroor e000423-0002
Search online for "error code e423 canon ir5065". Get plenty of hits - best one looks to be 'copytechnet. com'
Mar 02, 2012 | Office Equipment & Supplies
What is the username and password for web access to the cannon ir5065 copier
you might have to create your own account if you already own one of these cannon ir 5065 copiers and want some support
hope this helps
May 11, 2011 | Computers & Internet
My vw jetta 98 turns but wont start and also read the obd code p1582 0103 1613 and 1580
P1582- Idle Adaptation At Limit
0103- I believe is a MAF code and that is your air sensing system. could be not getting enough air. this one is not on the list.
P1613- MIL Call-Up Circuit Open/Short To Positive
P1580- Throttle Actuator B1 Malfunction
Here is the link I go the codes from so if you need it for future reference.
http://www.obd-codes.com/trouble_codes/volkswagen/
Jan 23, 2011 | 1998 Volkswagen Jetta
In canon 6570 when machine is switch ON error E000004-0106 and sometimes E000004-010 appears , what is the reason?
hi this is srinivas
sir
canon 6570 when machine is switch ON error E000004-0103 and sometimes E000004-010 appears , what is the reason?pls giv me a solution.
thank u
Sep 28, 2010 | Canon IMAGERUNNER 6570 Copier
My 2270 jambs paper from tray one every time. I changed the pickup rollers still no help. All my other trays feed properly even the stack bypass
Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation 0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint adheres to surface of vertical path roller
Description
Since a type of paper that can easily generate lint was used, the paper lint adhered to the surface of the vertical path roller and decreased the paper feed performance of the roller, causing the jam code "0105."
Depending on paper sources, the following jams occur.
- Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10 delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
- Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2 (cassette pedestal) delay jam)
To prevent this, a vertical path roller to which paper is hart do adhere was used for the following machines (the color of the roller was changed from black to gray).
- iR2230 120V THF03592 and later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606 and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596 and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439 and later/230V KFR02186 and later/230V CA SKQ01030 and later Field Remedy
When the symptom occurs with the machine without the foregoing serial numbers, replace the vertical path roller.
Kindly rate me !!!!!!!!thank mate.
Sep 23, 2009 | Canon imageRUNNER 2270 Copier
64 people viewed this question
k24674
jasbo
jasbo
