Question about John Deere Garden
Will not start with key - John Deere Garden
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Hello Tim, Had the same problem the ignition switch wears out. A simple fix I replaced it with a new one from ebay.com and delivered to UK within 4 days.
Hope it helps
Steve
Posted on Oct 12, 2013
I what to know how to input simulation program to clear maintanance code CA on Mx2610 sharp copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Feb 10, 2016 | Sharp Office Equipment & Supplies
What causes an error mssage of: Restart now or key is needed in a Ford Edge.
Driving 4. Start - press the START/STOP button (for any length of time) while applying the brake pedal. Note: The indicator light on the start button will illuminate when the vehicle is in on mode and when the engine is started. There may be areas inside your vehicle where the IA key is not detected. If the message NO KEY DETECTED appears on your message center when you press the START/STOP button, it may be necessary to move your IA key to another area within the vehicle. The IA key may not be detected near the roof (between the driver or passenger sunvisor and the roof, or in the overhead console area) or in the extreme corners of the rear package tray, near your audio speakers. It is not recommended that you stow the IA key in these locations. If you move the IA key to a location where it has been detected before and you still see the NO KEY DETECTED message, your IA key's battery may be low or you may be in an area with excessive radio frequency interference. If this occurs, you can use the back-up method to start your vehicle (see below). Back-up method of starting: Your IA key uses a radio frequency signal to communicate with your vehicle and authorize your vehicle to start when you press the START/STOP button and apply the brake pedal. If excessive radio frequency interference is present in the area, or if the battery in your IA key is low, it may be necessary to start your car by inserting the IA key in the back-up slot, located at the front of the center console storage compartment. Insert the IA key into the slot with buttons facing down and with key ring out. After inserting the IA key into the back-up slot, use the START/STOP button and brake pedal to start your vehicle as usual. The vehicle should respond normally as long as the IA key is in the back-up slot. Once the vehicle is started, the IA key can be removed from the back-up slot, if desired. Fast restart feature: The Fast Restart feature allows you to re-start your vehicle within 20 seconds of switching the vehicle off, if a valid IA key is not present when the vehicle is switched off. When you switch your vehicle off without an IA key in the passenger compartment or 238 2012 Edge (edg) Owners Guide, 1st Printing USA (fus)
Apr 06, 2015 | Ford Edge Cars & Trucks
How to activate simulation mode mx-m264n
OR
When the
Aug 25, 2014 | Sharp M264N Copy Machine
Kyocera3035 total clear
enter '1087' '1087' using the numeric keys
press the start key
enter '251' use the zoom key to select 'CLR' then press start key
Enter "001" using the zoom
+/- keys or numeric keys
and press the start key. to exited key
Jun 28, 2014 | Kyocera TASKalfa 180 Copier
How to reset the Maintenance indicator sign in SHARP AR 5618
OR
When the
Dec 09, 2012 | Sharp AR-5320 Black and White Copier
Starting disabled
try another key the one your using might have lost programming then if it starts with the other key restart it with the unprogrammed key within seconds of shutting it off with the key that works
Sep 21, 2012 | 2005 Saturn Relay 3
What can i do to program key for frod expedition 1997
In order to program your own chipped keys you need 2 keys that will start the vehicle. Start by putting the first key that starts the vehicle into the ignition and turn it to the run position(not the start position) and back to the off position. Within 10 seconds repeat this step with the second key that starts it. Then within 10 seconds put in the new key and turn it to the start position. The vehicle should turn on and the new key will be programmed. If you do not have 2 keys that start the vehicle then you will have to take it to a Ford dealership so that they can program new keys for you.
Mar 08, 2011 | 1997 Ford Expedition
My smart key is not working. i opened the door with the key part located inside the fob. is there a way to start the car with this key part? i do not see a key hole
Hello. Your smart key needs the battery replaced.
You can start the car, with a weak smart-key battery.
Position the smart key right above the start button. The Smart-key receiver will communicate with the smart key passively. The smart key must be held on the dash, above the start button.
Nov 30, 2009 | 2007 Toyota Avalon
I just got a key for my 1998 cadillac sts but it will not start the car what do i do? It will open the doors and the alarm goes off but the car will not start.
Leave key in ignition and turn to ON (do not start) Leave in on position for exactly 10 minutes. After 10 minutes is up and your anti-theft light is off, then immediately start the car.
Sometimes the key also need to be reprogrammed for the car.
insert the key and turn the key to "on". The DIC will say "Remove Key, Starting Disabled", and the security light will remain on.
approx. 10 minutes later. Remove the key. wait 10 seconds and repeat this another two times, for a total of 30 minutes "key-in" time.
Now insert your key and start the engine.
To learn additional keys:
Start the engine up with a working key. Shut the engine off, and within 10 seconds, insert the next key you want to learn and turn it to "ON". When the security light goes out, that key is programmed. Repeat for the next key, up to 10 keys can be programmed per car.
Oct 12, 2009 | 1998 Cadillac DeVille
When I switch on the copier display H and than 4.. please solve my problem with thanks.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
If the machine dies enter code 14 then press start, the machine will reboot normal, if the problem persist, the fuser unit needs replacement
May 05, 2008 | Toshiba e-Studio 161 Copier Copier
Garden Logo
109 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
