Question about Dishwashers
I have a model wmid Hobart dishwasher that wont get the water hot what heats the water
  • 119 Answers
Proper temp water has to be supplied to it. It does not have heaters. Ifit still has two solenoid valves, one(wash) has to have 150F and the other one(rinse) has to have 180F. Or you can supply 160F to both valves.
Posted on Nov 25, 2013
4 Suggested Answers
SOURCE: Hobart AM-14 water temperature not maintained
Hobart AM-14 will wash and rinse in manual, but not in automatic
Posted on Dec 10, 2009
  • 110 Answers
SOURCE: Hobart dishwasher model LX30H displays -5 on
by the way you're describing the problem, i would have to say there is something wrong with your control board. part#473173 can be bought @ any hobart office in your area. dont forget to vote
Posted on Feb 13, 2010
Testimonial: "Turns out it was mice eaten wiring."
SOURCE: wanted hobart dishwasher model am700 manual
wanted hobart dishwasher model am700 manual, where could I find it
Posted on Nov 21, 2011
Hobart AM15 dishwasher is not getting to 180' on the sanitizing cycle. How can I increase the temperature? Presently, centers around 177' when it is sanitizng
Try running the hot water into the sink immediately before you turn on your dishwasher. That will get hot water from your heater to dishwasher faster & help with the sanitizing cycle heat
Sep 06, 2017 | Hobart Dishwashers
Hobart dishwasher wont fill and motor hums
Hi SubaruB4
it may be the electric valve where the water comes in if it doesn't open when switched on water wont enter
Dec 26, 2017 | Hobart Dishwashers
AM14 Display will stay in Rinse Cycle
see this probably causes:
Water-heating cycle
the heating will be importante, test the hot water, and heating elements
Timer
test the timer for contact, and probably defective.see the diagram attached.
May 07, 2012 | Hobart AM14-253 Free-standing Dishwasher
I have a LXiC Hobart dishmachine I do not want to use Sanitizer because my hot water is very hot. How do you disable the sanitizer pump and alarm? H.
Do you realize that to sanitize with hot water alone requires 180 degree F water? I am a hobart technician and I've never seen any business or residence with hot water anywhere near that. Residential hot water is generally approx. 120, Commercial locations generally use approx. 140, but never near 180 (tap water that hot would be a severe safety problem). Hobart LXIH machines use a built in booster heater to boost the temperature of the incoming hot water up to the required 180 deg.
Jul 01, 2011 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Do all Hobart dishwashers have a element in them for wash water and rinse water
All Hobart dishwashers will have a wash tank heating element, but the rinse water is not heated by the dishwasher, unless it has a built-in booster heater. Usually a separate booster heater is used to heat rinse water to 180-190 deg. F for hot water sanitation.
Aug 07, 2010 | Hobart AM14C-155 Dishwasher
Dishwasher does not spray hot water
Can you give me a little more detail?Is this part inside or outside the machine?Any wires connected to it?What do you mean by base water source?I'm a hobart tech.
Feb 25, 2009 | Hobart AM14-253 Free-standing Dishwasher
Rinse not hot enough
145 degree is just your hot water temp and that your dishwasher hot water booster is not working assuming that this machine has worked in the past to produce final rinse water above 180 degrees. Remove the bottom panel and to the right you will see the booster tank, look for a nickel size component with a small red button on it. Try pushing on it to reset it. If that does not work, check for voltage at your heating element on your booster tank. (the thicker wires) If voltage is present then your heating elements need replacing.
Nov 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
