Question about Drills
When starting Ryobi 101l miter saw breaker trips
  • john conlan
    john conlan Oct 12, 2013
    When I push the trigger the saw starts then the breaker kicks off.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 108 Answers
Check the specs of the saw and take it from there
Posted on Nov 06, 2013
How do I fix the spring on the switch for a 10 inch ryobi miter saw? I can hear it rattling around and the switch won't work. Also plastic screws holding handle together are broken.
Hello Anonymous,
First locate the model number of your Ryobi Miter saw... then search Google for Ryobi Miter saw replacement parts... one result I got is below:
http://www.mastertoolrepair.com/ryobi-power-tool-parts-ryobi-miter-saw-parts-c-873_895_937.html
Try that link, select your Ryobi saw model and zoom into the provided drawings so you can locate the switch, screws, and spring (if needed). The part numbers are supplied and you can order them online easily on that same link... Then just repair your saw with the new parts. As you already noticed, the saw is easy to disassemble and get access to the parts for repair. Have fun and good luck...
RYOBI Miter Saw Parts
Mar 10, 2015 | Ryobi 10 In Miter Saw With Laser
Ryobi miter saw laser is way off. I can get it parallel, but it's about 1 inch away from the actual cut line. How can I fix the laser side-to-side?
Forget it. The lazer site gets obscured and useless after 5 minutes of cutting. It is the most useless improvement I've seen on a power tool in 40 years.
Feb 22, 2015 | Ryobi 10 In Miter Saw With Laser
Brand new out the box dw716 dewalt compound dual bevel miter saw cut one board & quit. Left it alone for about 10 minutes & it worked when we came back. Made about 10 more cuts & it stopped again. We are...
I would return it to the store, or have it fixed under warranty. You obviously have a defective saw. Dewalt is a reputable company, and they make high quality tools, but defects do op up once in a while from all manufacturers.
It sounds like your saw has a defective heat sensor, and it is sensing the temperature incorrectly and shutting the saw off to protect it.
Dec 12, 2014 | Saws
I just bought a brand new Ryobi saw from a neighbor but he couldn't find the manual. TS1141L 7 1/4" miter saw how do i get one?
Try this site. http://powertool.manualsonline.com/manuals/mfg/ryobi/ts1341.html I could not find your exact model. If this is not close to what you have then there are many other models to chose from. Just click on "ryobi saw" above the manual to see the rest of the models. You should find something very similiar. Thanks and please rate.
Sep 05, 2011 | Ryobi 10 In Miter Saw With Laser
I have a ryobi 10" mitre saw and i took the guard
I don't know but if you have figured it out let me know. I have same prroblem.
Apr 19, 2011 | Ryobi 10 In Miter Saw With Laser
How do i unlock the safety position on my Ryobi miter saw?
There should be a metal pin on the back left side(tool facing you) near the pivot point. Just pull this in or out to lock/unlock the safety position.
Mar 02, 2011 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Ryobi circular saw --it keeps tripping my breaker
Possible bad circuit breaker. If on a ground fault sensing circuit, the saw may have electrical leakage from it's internal wiring/motor to case ground (a possible problem if you have been using a metal cutting blade)(test by using a 3-pin to 2-pin adapter [no ground pin]). The circuit breaker may not be rated for the starting load of the saw (check the saw load rating against the breaker current rating--the breaker rating should be at least 25% higher). Possible excess current draw in the saw if any of the motor windings have shorted together for whatever reason. Hope this helps!
Feb 06, 2010 | Ryobi Circular Saw W/Dual Laser
I have an old Ryobi 8 1/4 Miter Saw
call Ryobi direct at 1-800-525-2579, they do not have older manuals online for download but they can send one to you.
Sep 30, 2009 | Saws
Drills Logo
41 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
