Question about Intuit QuickBooks Pro 2003 Single User Retail - Ships SAME business day. S&H $5.95+ (028287006546)
Quickbooks 2001 won't install on Vista 64 laptop. I tried the "run as administrator" on the setup file but still fails to install. Anyone have a solution? Thanks!
    Champion:
  • Intuit Expert
  • 237 Answers
2001 is too old to run on Vista. You need a newer version.
Posted on Dec 03, 2014
5 Suggested Answers
QBPOSScott
  • 237 Answers
SOURCE: launch Quickbooks pro 2005 for first time with error
This usually indicates a bad registry in windows, where the admin accounts are damaged. You can try creating a new user with admin rights. If the problem persists, you will probably need to do a system recover on the laptop, setting it back to factory specifications.
Backup any data you want to save first.
Posted on Nov 16, 2008
SOURCE: Error message when installing QuickBooks 2005 to new 64 bit compu
Hello, I found this on another web site intuit community. I tried this and it works. A couple of people said they had to run this each time they signed on but i have not had to.
Welcome to the community forums. One thing that I notice with your error log is that all the missing files are .dll files. I would suggest running Reboot.bat which re-registers the QuickBooks .dll files.
Do a search on your computer for reboot.bat (there is a seperate one for each version) and run the reboot.bat that corresponds to version of QuickBooks you are having a problem with.
It worked for me and I am so happy because as stated QB not longer supports 2005.
Lorene renie1954@yahoo.com
Le me know how it goes for you
Posted on Jan 11, 2009
to: niftyneeda, I also read that qb2005 is not compatable for vista, so that may be why you continue to hae problem, but is seems as though you found a way around it. I just purchased a new computer and also new qb. bestbuy.com had qb for 99.99 1/2 the store price.
Posted on Jan 15, 2009
SOURCE: is quick books 2003 Vista compatabile?
QuickBooks Pro 2003 can run on Windows Vista. Right-click a shortcut to open Quickbooks (or qbw32.exe directly) and click on Properties. Select the Compatibility tab. Under Compatibility Mode, check the box and select Windows XP (Service Pack 2) from the list. Under privilege level, select "Run this program as an administrator." Select OK and everything will work.
Posted on Apr 06, 2009
I downloaded google earth setup but when asked to be executed and accept it deapears
I had the same problem last night using Vista 64 bit, downloaded 3 times eventually finding the installer downloaded in C:/ Users/ Downloads
I cut and pasted the installer to the desktop and ran it from there, worked for me without having to "run as administrator". Then had to go into Programmes / find the downloaded files under Google open the client folder and copy the .exe file for Google earth to the desktop.
What a pain...
Jul 28, 2011 | Computers & Internet
Can anyone supply the drivers for the yuan mpg 200c multimedia conrtoller PCI card please?
These were tricky drivers to track down - I found them on a Chinese website and have uploaded them onto megaupload.com. I personally checked them out to determine that they are the correct drivers and contain no viruses.
1. Follow this link: http://www.megaupload.com/?d=RCKXEU2J
2. Download the file and extract to desktop.
3. Double click Setup.exe to install the drivers.
Note: If the driver installation fails, then try and use compatibility mode. You can do this by right-clicking on Setup.exe and clicking Properties. Select the Compatibility tab and check box for Windows XP Service Pack 2. If that fails, then select Windows 98. These drivers almost certainly won't work for a 64 bit operating system as they are old drivers. You may some issues with compatibility particularly if you are running Windows Vista or Windows 7.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
May 24, 2011 | Computers & Internet
Installation Windows 7 - quickbooks will not reinstall
Is the qucikbooks 2004/2005 a upgrade or a full version ?
if its a full version right button click the setup.exe or whatever the install program is called , troubleshoot compatiblity , also try selecting the run as administrator as you may not have the right to install the program ?
Regards
GeWiz.
Oct 20, 2009 | Microsoft Office Professional 2007 Full...
How can i make quickbooks 2005 run on a vista laptop?
Here is how to load and activate Quickbooks 2005 on Vista...
First of all, if you already have an activated copy of QuickBooks 2005 on another computer open it and go to "help" "my license information" and print this out so you have the details needed for activating your reinstalled copy (you don't need a fresh activation key and you may have trouble getting one as QuickBooks 2005 is no longer supported by Intuit).
On your new Vista computer, insert the QuickBooks CD but cancel any program install windows that pop up. Go to my computer and find setup.exe on the CD, right click and select the option to "run as administrator"
Once installed, navigate to the QuickBooks folder on your hard drive (typically C:\Program Files\Intuit\QuickBooks) right click on QB32.exe and on the compatibility tab select both Disable visual themes" and "run as adminstrator". Now open this file to run QuickBooks and select "file" "Update QuickBooks" to download and install all updates. QuickBooks will not work properly until you have downloaded the updates, closed and reopened the program.
I had problems with activation but I got around this by unplugging my network cable so that I had no internet connection. If you run QuickBooks without an internet connection, when the screen pops up asking you to "activate" click next and the screen to enter your license details will appear. enter your details (printed out from your previous installation) and you are done. You can restore the internet connection and use QuickBooks 2005 normally.
Andrew
Jul 09, 2009 | Intuit QuickBooks: Pro 2005 for PC
VAIO VGN-AR630E Drivers for Vista Ultimate
Vista Home premium drivers will work perfectly with Windows Vista Ultimate. When installing Vaio event service and Vaio Control center make sure that you run setup file as administrator. Right-click the setup file and select option "run as administrator". By reinstalling utilities this way they will work perfectly well
May 17, 2009 | Sony VAIO VGN-AR630E Notebook
Jan 06, 2009 | Intuit QuickBooks: Pro 2005 for PC
Samsung ml-1740 printer - their driver not compatible with my Windows Vista
Try to install the software by clicking the right button of mouse on it and chose 'run as administrator ' from drop down menu.
Before installing do the following:
Unplug pinter USB.
Remove printer from installed printers (delete ) from Windows control panel.
Keep printer usb cable unplugged when you start driver setup software, you will be asked by setup wizard when to plug in the cable, or reconnect after installation.
If it still does not work, do a system restore to a date before you plugged in the printer for the first time, then repeate software setup as above.
If it still does not go you may need to reinstall Vista or replace the printer, one of the system files or regisries entries had developed a problem with printer driver, and is not easy to locate and remove the files concerned one by one.
Regards
Sep 01, 2008 | Samsung ML1740 Laser Printer
Is quick books 2003 Vista compatabile?
Feb 14, 2008 | Intuit QuickBooks Pro 2003 Single User...
Computers & Internet Logo
541 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
