Question about Husqvarna Sewing Machines
I'm having trouble reconnecting the throttle cable to the carb on my Husqvarna 223L weed trimmer at the carb.
HUSQVARNA LILY HOW TO PUT THE COVER OVER THE THREAD
The cover may have come with or without the hinges. These snap on to the cover. If they have become disconnected you may need to remove the covers on the machine to reconnect. Two screws on the back one on the operators left and 4 on the bottom. Then apply the secret slap to take the rear cover off.
Dec 20, 2016 | Husqvarna Sewing Machines
Hello I have a husky over locker 540 but it didn't come with a manual I've had it for years I want to know how to thread it and us it please I need help
If by Husky you mean Husqvarna search in google for Husqvarna overlocker 540 pdf and there should be a manual you can download for free. If you are still having trouble email customer service.
Nov 22, 2014 | Sewing Machines
Ran straight out the box
Sounds like you ran it with the choke on - best bet is to take the carburetor apart and make sure the float isn\'t suck and clean it out. Take out the spark plug and spray it with carb cleaner and dry it - wipe out the spark plug area. Reinstall the plug and carb. Give it a pull a few times let it run then adjust the throttle to the lowest setting and then back to the desired operating speed. Listen to the engine you should be able to hear the choke cut off when you adjust the throttle.
Jan 12, 2013 | Husqvarna Sewing Machines
Need new blades for my 560ED t -- can't find
I would contact Husqvarna and ask if there is an acceptable replacement for your model.
Sep 11, 2012 | Husqvarna Sewing Machines
I'm having trouble with my husqvarna rose plus hoop and designs. i need a manual to help i think
Call Husqvarna Viking at: 1-800-474-6437, they may be able to provide you with a photo copy of the original owners manual.
Oct 28, 2009 | Husqvarna Rose
How do i string my husqvarna 125l trimmer?
wrong category. This category is for sewing machines. If still a problem, resubmit in correct category.
Aug 03, 2009 | Husqvarna Viking 1
How to load the line on the Husqvarna 125l trimmer
Wrong category. This one is for sewing machines. Suggest resubmitting in correct category if still a problem.
Mar 18, 2009 | Husqvarna Viking 1
HOw do i thread the bobbin of a viking romeo sewing machine
Take a look at this Sewusa site for threading diagrams.........even if not your model, you may be able to work it out from a similar one.
Still having troubles.........Contact Husqvarna HQ in your country or a local dealer, they will be sure to assist.
Jun 12, 2008 | Husqvarna Viking 1
What type of grease do I need?
You have somehow posted a hedge trimmer question amongst a sewing machine forum, so I would suggest a re-post in a different forum to maximise responses !
Apr 19, 2008 | Sewing Machines
Sewing Machines Logo
24 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
