Question about YouTube Videos
How to remove headliner in 2009 peterbilt ultra cab
I have a 2016 Peterbilt 567.A/c works great. heater will not warm the cab. it just blows cold qambient air even if the engine is at 200 degrees
you can get help from the service and repair manual which will guide you to fix the problem with diagram and you cna get the manual from the given link http://toolsnyou.com/
Dec 11, 2017 | Cars & Trucks
Headliner on my sunroof has fallen down. It is a 2009 Lincoln MKX. How do I fix it?
You will need to remove the entire headliner, being careful not to crack the foam it is constructed. You will need to remove all the plastic door pillar covers, any clothes hangers, the dome light, etc.
You can purchase headliner fabric and adhesive at most fabric stores. The personnel there will assist you in getting the correct adhesive. You must remove all the old headliner fabric and backing pad material to get to the foam core for installation of the new headliner fabric. Lay out the fabric and cut it to size, allowing for some overlap in case you err slightly when positioning it. You will apply the adhesive to the foam core and to the back of the headliner fabric. It is a contact-type cement. Carefully position the fabric over the foam core and work from the center out to position it, being careful not to trap wrinkles or to stretch the fabric excessively. Trim off the excess and reinstall headliner.
Dec 31, 2014 | 2009 Lincoln MKX AWD
How to remove seatbelt pillar covers in a 2002 tacoma standard cab
big screwdriver and wrench them the covers are held in with plastic clips and they will break on pulling the covers thats for sure but the new clips are not expensive from a motor factror who now have a trico catalogue
Nov 16, 2013 | 2002 Toyota Tacoma
2009 harley ultra classic accessory switch
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
Harley Ignition switch removal from 2009 Street Glide
Apr 16, 2012 | 2009 Harley Davidson FLHTCU Ultra Classic...
How do you remove the luggage racks on top of a 2009 chevy traverse?
I believe the center pieces are glued/double sided taped to the roof and the out side rails are bolted to the roof, need to remove the inside headliner.and then plug the holes.
Aug 26, 2011 | 2009 Chevrolet Traverse
Headliner removal
i would like to see a video of how to remove the trim and roof headliner on a 1990 cadalliac sedan deville
Apr 01, 2010 | 2009 Scion tC
At hiway speeds the top of th cab buckles due to the wind sounds like someone pounding on top of the cab there seems there is no support between the roof and the head liner.
I WOULD TAKE IT BACK TO THE DEALER ,BUT IF NOT ,YOU CAN PULL THE HEADLINER, AND WHERE THE CROSS BEAMS WERE NOT GLUED PROPERLY, USE A CAN OF GREAT STUFF FROM HOME DEPOT ETC, AND SPRAY IT BETWEEN THE CROSSBEAMS & THE ROOF ,ALLOWIT TIME TO EXPAND AND DRY BEFORE REPLACING THE HEADLINER ,YOU MADE NEED TO TRIM SOME OF THE GREAT STUFF OFF SO THE HEADLINER WILL FITS BACK IN PLACE RIGHT.
Dec 04, 2009 | 2008 Ford F-350
How do i remove the headliner board from gmc
You remove any of the trim that is contacting the headliner,remove light in the center,remove visors and any hooks that are there to hang things on ,Most of your trim has push in retainers handles and hooks,seat belts should have screws inthem.
Aug 30, 2009 | 1992 GMC Sierra
2000 L4310 Cab over kubota, ac doesn't work, can;t find condenser
the condenser is in the front of the radiator where the radiator fan can cool it
Jul 06, 2009 | Heating & Cooling
Wet Headliner
You likely have a water leak around the 3rd brake light mounted on the top rear of the cab. I had this same issue on my 96 Ranger Supercab and found that the foam seal had gone bad and was allowing water to leak into the back of the headliner around the light fixture. It ended up soaking the headliner from one side to the other as the headliner acts as a 'wick'. You can repair this issue by either replacing the sealant around the 3rd brake light or replacing the brake light. There are two screws which secure the 3rd brake light assembly to the back of the cab. Remove these and it will pop right out. I upgraded mine to an LED light when I replaced it. That solved two issues at once as I'll never need to change a bulb there again. If you want to be cheaper you can not replace the light and just seal it with rubber silicone sealer.
Jan 14, 2009 | 1990 Ford Ranger SuperCab
YouTube Videos Logo
386 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
