Question about Reebok treadmill ice-run
Reebok Ice treadmill smells of burning after about 30 minutes of use and belt is slipping on left side when running
  • Michele Stott
    Michele Stott Oct 11, 2013
    Thank you for this but my machine is a Reebok Ice Treadmill. Are you able to provide a video for this please? Kind regards.
    Top Expert:
  • Reebok Master
  • 12,223 Answers
See the video attached. lube the front rollers too front+back
God bless you
Posted on Oct 11, 2013
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
Posted on May 27, 2009
bwinton
  • 83 Answers
SOURCE: treadmill belt slipping
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: Reebok 8050es treadmill walking belt has started
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
Posted on May 06, 2010
maxtreadmill
  • 832 Answers
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
Posted on May 14, 2010
  • 218 Answers
SOURCE: hi i got a reebok i run treadmill power light on
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Posted on Aug 11, 2010
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
Reebok T3.2 treadmill stop after couple of minutes
7 amps wth no load is kind of high for this.. be looking at the surface that the belt is on.. and the rollers for excess drag..this should completely freewheel when no one is on it..
Jan 19, 2014 | Reebok Exercise & Fitness
Smell of burn when in use
1) LUBE THE DECK BELT INMEDIATELY , THIS HAPPEN BECAUSE THE LACK OF MAINTENANCE SCHEDULE SEE YOUR OWNER MANUAL.maybe you have some deck Worn.
2) LUBE THE ROLLER BEARING INMEDIATELY, LACK OF MAINTENANCE.
God bless you
Sep 25, 2012 | Reebok treadmill i-run s
Belt starting slipping, adjusted according to User's manual...belt still slips.
hi,
Here is the steps to adjust the treadmill belt,
(1). Turn off the treadmill and remove the plug from the wall outlet to make sure it doesn't turn on during the readjustment process.
(2).Tighten the roller bolts on the rear of the treadmill belt with an Allen wrench. Tighten both the right and left bolts with 1/4 turns.
(3).Avoid tightening the bolts more than 1/4 of a turn at a time. If the belt is tightened too much, it may cause damage to the belt, which would require a replacement.
(4).Plug the treadmill into the wall and press "Power."
(5). Select a program and begin walking. If the treadmill is still slipping, turn off the treadmill, unplug it and tighten the bolt a 1/4 turn again until it is properly adjusted.
watch the following video which will help you to do the same.All brand hve the same procedure for tighten the walking belt.
If then also the belt is slipping then you have to replace the running belt with a new one.
ok
Sep 03, 2011 | Reebok T 1280 Treadmill
Belt slipping
You mean front- to-back or side- to-side?
If its side to side, adjust the allen bolts at the bottom front of the treadmill. If its front to back, and your treadmill is at least a few years old, the belt is probably stretched and needs replacing. You can get a quote for a new belt at http://www.treadmill-world.com/parts-manuals.html
Dec 21, 2010 | Reebok 8050 ES Treadmill
How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Mar 07, 2010 | Reebok Exercise & Fitness
How do i lubricant my treadmill
it is an indicator that the belt needs lubricating. turn the power off, and lift up one side of the belt and spray a small amount of lubricant underneath the belt, onto the running board. repeat this step on the other side. turn the treadmill on and run it for a few minutes to spread the lubricant. the oil light should now go off.
this should be repeated every 5-6 months to keep the board lubricated and to reduce friction between the belt and board and will lengthen the life of your treadmill.
Dec 19, 2009 | Reebok New York Giants Eli Manning Jersey
Treadmill belt slipping
Mar 22, 2009 | Reebok Exercise & Fitness
Reebok treadmill ice-run Logo
183 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
