Question about Logitech Z623
Right speaker stopped working
Everithing works exept sound from right speaker?
2 Suggested Answers
SOURCE: one speaker wont work
if u have experience with the soldering of the terminals then you can open the speaker casing of the sub woofer and then solder the right speaker input wire.
dont do this if you have no previous experience and DISCONNECT THE POWER SUPPLY before doing any work inside.
Posted on Apr 19, 2009
Hi, I have acer aspire 5520,2 Gb RAM... When I turn on my acer,everithing works just fine,exept monitor,it remains black,When I try ecternal monitor,it works fine,windows wors fine to,everithing but the...
Aspire 5520 has LCD Display. The screen displays becomes dark/ dim if there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. These parts are inside the LCD screen. Either of the parts may be faulty or in some rare cases both. Also, the video data cable may be loose or faulty, which can be identified only after opening the top cover.
So, my advice is that you get it properly checked by any professional for replacement of Inverter or CCFL.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 22, 2011 | Acer Aspire 5520-5579 Notebook
Sound system not working, and its not the speakers
Do you have the correct drivers installed?Go to support.dell.com.Input your machine type choose the correct driver and download it.Once you have completed the download,uninstall the present drivers.Click on the file you downloaded follow the instructions this will install the drivers.
Good luck
Oct 14, 2009 | Dell Dimension 3000® Pentium® 4...
I just installed a used Asrock K7S41GX board which is working just fine exept I have no sound through my external speakers. The internal speaker on the the board beeps on startup but nothing after that. Do...
If you hear just one short beep on the onboard speaker it means that everything is fine. You should download the drivers for the onboard sound from Asrock website.
May 18, 2009 | Asrock K7S41GX Motherboard
My rca television works fine exept for the sound
There is a switch on the back of the TV that toggles between the built in speakers or the external speakers. Try flipping it and see what happens.
Jul 21, 2008 | RCA MM36100 36" TV
SPEAKER FRONT RIGHT NOT WORKING?
ive got the same problem but with my z5500
wonder what it is?
Mar 16, 2008 | Logitech Z-5300 Computer Speakers
No sound from speakers on ACER Aspire.
have you checked the sound card from bios?is there everithing ok?have you checked the driver instaled in start/run/dxdiag?do you have a sound card onboard or a stand alone one?It may be damaged too.
check all this after you are sure that in the operating sistem,windows lets say is everything ok from control panel/sounds and audio devices.
if it is not a software problem,than your card must be replaced and for this visit a specialised Acer service.they will test and recomand you the best solution
bye bye
Feb 06, 2008 | Acer Aspireā„¢ T180 PC Desktop
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
Logitech Z623 Logo
20 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
