Question about DBX Omega 1-Rider Towable Tube
There are no instructions with this tube. I can take the cap off but the air will not let out. Obviosly doing something wrong.
Fuel cap light on x few wks.replaced it to no avail.Also says -200 miles+ Service B.Any ideas other than taking it to dealership?
If you hear that air rush when you remove the cap to refuel after running a little, there's nothing wrong with the cap. If you do not hear that air rush, your system is open and not sealed. You've replaced the cap to no avail, light still on because there is an air/vacuum leak somewhere in your system. It could possibly be your fill tube connection clamps or a pinhole in the fill tube hose. This simple stuff can throw the computer off and make it think something else is faulty. Something physical, not electrical that the computer is not connected to, like the fill tube, will not show as such on a readout. Remove the fuel filter and return line connection and plug them both from the tank so you can pressurize the tank wit a little air to listen for a leak. Once found re-connect the lines and repair the leak.
Jul 13, 2017 | Cars & Trucks
Gas cap code put new one on check egine light still on
could be your oxygen sensor or catalytic converter.. You may check for leaks in manifold as well.Mass air sensor could also be at fault.
Oct 13, 2014 | 2002 Cadillac Deville
Lg 1.5 tr split ac capilary replaced.size 5.0 ,length 1 1/2 ft. gas charging done.ac running for 20 mints.after 10.7 amps incressing and of the compressor over heat.i will replaced 50+4 running...
The best practice when replacing a cap tube is to replace it with the identical size and length of the old cap tube. Also, you must run it in the same way, if the cap tube was soldered to the suction line in any area then the replacement should also be soldered to the suction line. The old cap tube should have been stretched out, measured and gauged with a cap tube gauge. If you just went by load, it appears your cap tube is the wrong size, should be a #4 or .064ID and not a #5 .028ID. This is just based on some cap tube sizing charts I looked at assuming you have a single cap tube and not a multi circuit evap. Other than the cap tube the symptoms point to a system that was overcharged, dirty condenser, condenser fan motor not running. If you have a way to check suction and discharge pressures this will be the best way to see what is going on.
May 10, 2014 | Heating & Cooling
I have a jenn air jgs9900bds maytag and the display doesnt work at all it beeps but it doesnt do anything...i cant cook obviosly by this problem helpppp!!!
On something like this you have 3 components that could cause this symptom. The touch pad, display & main control board. The main control board should provide 12 volts DC to the touch pad & display boards. Test pins J1-2 to J1-1, J4-2 to J1-1 & J5-1 to J1-1 should all have 12 volts DC.
Oct 15, 2011 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Topeak Pocket Shock pump~ can't find instructions... attempted to use but seems like I loose air..... help
When you place the pump head on the valve make sure you flip the lever, this will seal the pump and air will not come back out. Also make sure your valve is not bent or loose. If your still losing air take the pump and bike into any bike shop and they will be more than happy to show you how to use it, and bonus if there is something wrong with either the tube or pump they will be able to diagnose and provide a solution.
Apr 07, 2011 | Topeak Cycling
Air pressure out through the suction tube of liquid my spray gun - DeVilbiss jga 558
If your getting air down the suction pipe your air cap isnt tight enough or its the wrong one.
Oct 21, 2010 | Air Tools & Compressors
Just got answer from Matthew about replacing distributor cap on 1999 Sebring. Thanks, but what I really needed to know is if the intake manifold and all the other parts that eneded to com off to replace 3...
Not sure about your engine size so please pick your model:
2.5L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    • Bolt holding air inlet resonator to intake manifold.
    • Clamps holding air cleaner cover to air cleaner housing.
    • PCV make-up air hose from air inlet tube.
    • Hose clamp at throttle body.
    • Air inlet tube, resonator and air cleaner cover.
    • EGR tube.
    • Spark plug cables from distributor cap.
  3. Loosen distributor cap hold down screws and remove cap
    NOTE The rotor is friction-fitted to the distributor shaft and can be pulled straight off.
  4. Transfer cables from old cap to new cap. The cap and cables are numbered with their corresponding cylinder numbers.
Distributor cap—2.5L and 3.0L Engines
To install:
  1. Install or connect the following:
    • Distributor cap.
    • Distributor holddown washers and nuts and torque to 9 ft. lbs (13 Nm)
    • EGR tube.
    • Clamps holding air cleaner cover to air cleaner housing and securely tighten.
    • Bolt holding air inlet resonator to intake manifold and securely tighten.
3.0L Engine
    • Air cleaner
To install:
    2. Distributor rotor
    • Distributor cap
    NOTE Make sure the new cap has an O-ring in its base.
    • Distributor holddown washers and nuts and torque to 20 inch lbs. (2.3 Nm)
    • Air cleaner
  • Oct 26, 2009 | 1999 Chrysler Sebring
    I put a new gas cap on my 2003 F150 and after driving it a few miles it won't start. I can take the gas cap off and it will start fine. Is the vent tube clogged? Where is the vent tube if this is the...
    You have most likely obtained the wrong type of gas cap for your F150. Try using a similar gas cap from another vehicle you may own, or one of your friends. You can also try using the new gas cap on the other car to see if a similar problem occurs.
    Jul 13, 2009 | 1989 Ford F 250
    Where do you charge up the air condition for a 2003 poniac grand prix
    There should be ports on the right side of the vehicle hnder the hood. They will have palstic caps. The smaller one is for charging the a/c system. Good Luck
    Jul 09, 2009 | 2000 Pontiac Grand Prix
    DBX Omega 1-Rider Towable Tube Logo
    71 people viewed this question
    Top DBX Boating Experts
    Steve
    Steve
    ray gallant
    Andrew Taylor
    Andrew Taylor
    Are you a DBX Boating Expert? Answer questions, earn points and help others
