Question about Kenmore 22422 Top Load Washer
110 kenmore loader top 23812100
Will not drain. not lid switch. Runs first cycle and stops.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
If it is not the lid switch then it is the motor switch. Here is that part to order.
Posted on Oct 11, 2013
  • 71 Answers
SOURCE: Washer will not spin properly on a Kenmore 110 23812100
your pump is partially clogged or your drain hose is kinked
Posted on Dec 12, 2008
danromarris
  • 101 Answers
SOURCE: can't get top off kenmore washer model # 110 22852 100
No problem. What you want to do is this, remove the screws from the back panel first to remove that metal plate protecting the wires. Once off you need to take off the two covers on the sides of the control panel. There is one on each side, just pop them off. Once off you will see there is a screw under there holding the control panel in place. Remove the screws and that will lean back. Next take a flat head screw driver and put it under the lip of the lid on the front of the washer. I mean the lip that is about an inch down from the top on the front. Pry up and the whole lid will pop up. You will see the lid switch there held in by a screw, follow the wire to where it plugs in and unplug it and replace with the new one. Let me know if you have any other questions and if this was helpful to you. Always happy to help and good luck.
Posted on Jan 23, 2009
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 1937 Answers
SOURCE: kenmore 80 series model 110 23832100 - Washer
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110+23832100&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
See the following Whirlpool / Kenmore service manuals for these washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin
gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
All told, fixing ours cost less than $30 including about 16 oz. of 80-90 weight gear oil (from an auto parts store) instead of $170 plus service for a new transmission.
Posted on Mar 14, 2010
marka19
  • 1430 Answers
SOURCE: Replace "lid switch" on kenmore washer 110-20702-991
Go to www.appliancehelponline.com/servicemanual.html this will walk you thru the lid switch replacement.
Posted on May 12, 2010
Kenmore top loader mod. 110 29522801 does not run after filling with water. The lid switch could be bad. Are there other problems that should be addressed?
if the unit is filling with water it is not the lid switch because it will not fill with water if the lid is open
problem areas are the water level switch is not energizing the wash cycle as well as switching off the incoming water
if it is stopping the water but nothing else , have a technician check the program board
Jan 13, 2017 | Kenmore Washing Machines
Kenmore 110 washer fills and does the wash cycle but wont drain or spin. Totally shuts down after wash cycle. What do I need to replace
sounds as though the lid switch has gone bad, either that or the motor has lost the reverse winding on it.. most likely lid switch tho.
the lid switch is only "seen" by some older kenmore "110" series at the end of the wash cycle, or end of the rinse cycle. it purpose is to keep the unit from spinning if the lid is opened so no one looses an arm, etc.
generally the console on those machines hinges over backward so you can remove the cabinet top and 3 sides as a unit together..
the lid switch is under the machine top and isn't easily accessible without removing the cabinet.
May 20, 2010 | Washing Machines
No Spin Cycle in Kenmore 80 Series Top Loading Washer
First, see the Sears parts site for your washer: Following is the Sears site for Whirlpool (110.) models with your model number.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23812100
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Jan 18, 2010 | Kenmore 22422 Top Load Washer
Doesnt spin or drain
Sounds like its a pump problem if pump dosent work the rest of the cycle wont either maybe pump belt has come off or has broken hope this helps
Sep 06, 2009 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Dec 09, 2008 | Kenmore 23822 Top Load Washer
Kenmore Series 70 Top loader won't spin
it is a problem with the lid switch. check for continuity. if the lid is close , it should have continuity, if you open the lid, it should be open also.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Kenmore 23822 Top Load Washer
Kenmore 22422 Top Load Washer Logo
64 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
