Question about Exceed-RC RC Truck
Is the Exceed 1/10 scale Mad Crawler waterproof & will the Infinity Monster Truck tires & wheels fit the Mad Crawler?
Will a 235/70F16 tire fit on a 2001 chevy impala with out rubbing
Hi there:
Tire diameter can vary slightly for each tire model. When changing tire sizes, we recommend staying within 3% of the diameter/height of the original tire. Any more than this and you face the risk of brake failure.
I suggest to check this link: TireSizeCalculator
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 21, 2012 | Cars & Co Cars and Co Spare Part Exceed-RC...
I repaced all the arms and now i am having problems getting the toe in correct
make sure its lines up with rode to tire with groove from inside tire to the arm.
Feb 18, 2011 | Hobby Products International Hpi Savage X...
WHEN I START UP MY TRUCK THE WHEELS SPIN IS THAT IT DOES.I WANT TO KNOW IF THIER ANYWAY I CAN MAKE THEM STOP.
turn down your idle screw and adjust your low speed screw to fix the problem that made you turn your idle up in the first place if you let the truck idle for 7 1000s and you mash on the gas it will do one of 3 things:
1) a nice crisp throttle response= perfect low speed setting do not adjust
2) engine bogs down = too rich, lean out low speed screw 1/8th turn until fixed
3) truck revs up but shuts off= too lean, richen low speed screw 1/8th turn until fixed
Nov 20, 2010 | Exceed-RC 1/8TH Scale Exceed RC Nitro Gas...
Problems with RC engine not running right!
Theres a idle screw located on engine under airfilter, should be small flat head. Clockwise will stop the carb from closing thus not cutting engine of. Also make sure you run car slightly richer than leaner. Hope this helps.
Mar 31, 2010 | Exceed-RC 1/8TH .21 Tectonic Nitro...
Need to know what rims will fit on a 82 amc concord
mcdevito75 here, Ibelieve they were 15 inch rims all around.
Mar 18, 2010 | Cars & Co Cars and Co Spare Part Exceed-RC...
Differential problem
fit the factory size wheels ,not monster truck ballons
Dec 13, 2009 | 1997 Kia Sportage
The rear tires on my 88 pontiac firebird formula wont come off. i took the nuts off already
Sometimes the wheel seizes to the inner hub with rust. Assuming the vehicle is lifted onto a steady jack stand; try soaking the point of contact where the wheel touches the inner hub and the 5 lugs come through the wheel with WD-40 (or some other effective penetrating fluid) and then, after 15 minutes or so, hit the tire soundly with a 3# (or larger) hammer to break it free from the hub. If that doesn't work; heat the wheel around the hub with a butane torch and again hit the tire soundly with a large hammer to break it free from the hub.
Aug 03, 2009 | Cars & Co Cars and Co Spare Part Exceed-RC...
E maxx steering is too tight
You may have something too tight on your steering linkages, or you may just want to upgrade to a better servo. My Revo's servos are all metal gear and I have never had a problem with them. Receiver batteries on my truck were weak and the tires were hard to turn as well, so check your batteries
Apr 28, 2009 | Traxxas E-maxx Evx-2 Monster Truck
Exceed-RC RC Truck Logo
22 people viewed this question
Top Exceed-RC Toys Experts
jasiel murphy
Jerry Radcliffe
Tom Chichester
Are you an Exceed-RC Toy Expert? Answer questions, earn points and help others
