Question about Whirlpool Dishwashers
Whirlpool model GU1200XTL80 low water velocity to spinner under top rack< barely dribbles out. Already checked pump and water channel for detritus.
4 Suggested Answers
  • 423 Answers
SOURCE: whirlpool dishwasher top Spinner and top rack
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Posted on Sep 12, 2009
heatman101
  • 43501 Answers
SOURCE: Whirlpool Gold Dishwasher - GU2700XTSB The
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 20, 2011
  • 4 Answers
SOURCE: Recently my dishwasher KUDSO1FLSS2 is
If there afilter on the inlet hose it might need clening,if you have a partial blockage it will reduce the volume of water entering your appliance.Hope this helps.
Posted on May 14, 2011
Recently my dishwasher KUDSO1FLSS2 is not cleaning the top rack very well requiring multiple washings. Both the top spinner and mid rack spinner (under top rack) turn freely by hand but limited water...
May 14, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Whirlpool Gold Dishwasher - GU2700XTSB The top rack of the dishwasher is not cleaning. The bottom rack dishes clean fine. There are no clogs in either the bottom or top spinner arms, the plastic tube...
Dishwasher
How to Buy
heatman101
Jan 20, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
DISHES ON TOP RACK ARE NOT GETTING CLEAN TOP SPINNER NOT SPINNING POSSIBLY NOT ENOUGH WATER PRESSURE?
It would help if you provided the make and model of the dishwasher.
Most likely cause of not getting enough water pressure to top rack is the water diverter may be faulty.
Depending on the model - it is a small ball floating in a vertical channel which alternately opens and closes the bottom and top water inlets to the spray arms. Check part at Repair Clinic after selecting make & model of your dishwasher.
Jun 17, 2010 | Kenmore Dishwashers
Whirlpool dishwasher top spinner and top rack spinner is not putting out water or very little and not spinning. I have taken apart and cleaned everything including the sump / chopper, can't find any...
Sep 12, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Top rack not cleaning, possibly spinner not spinning?
Try twirling the spinner by hand to see if it is binding. If it looks ok then there could be something plugging the water passage to the spinner. If you have access to a water hose you could run water into that verticle passage pipe and see if there is an obstruction. If so it can be taken apart for cleaning.
May 13, 2009 | GE GSS1800H Built-in Dishwasher
Dishes not clean
There may be a couple of solutions to your problem. First, if you are not rinsing the dishes thoroughly before loading, your sump area in the bottom of the machine will get clogged, thus preventing enough velocity to reach top rack. Second, and most likely, your water inlet valve (or solenoid valve) is restricting. You have a timed fill mode through the timer and if the valve is not opening fully, you do not get the proper rate of flow into the machine. Replace the valve and your problem will most likely be solved.
Dec 01, 2008 | Maytag MDB7100AWB Dishwasher
Dishes and Flatware Don't Get Clean
Check to see that the removable cup rack on the left is seated correctly. One of the support legs of this rack is located above center of the spinner. If this leg is sitting on the top of the spinner rather than the center cross member of the main rack, the spinner will not move after that rack has been loaded.
Also check that the spinner is free moving once the draw is fully loaded, some plates can sit low enough to obstruct the spinner.
Mar 20, 2008 | Fisher DD603FCSS Dishwasher
I have a Whirlpool Gold GU98OSCGZ2 - low water level and dishes not clean
the water inlet valve needs to be replaced. remove the bottom panel. the valve is located on the left side behind the panel. pretty easy to replace
Nov 28, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
56 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
