2011 toyota rav4 limited
I have a 2011 Rav4 AWD and I believe that the front passenger wheel bearing or hub assembly may be going bad cause of the roar it`s making. The part that causes me to be unsure is no play at all in the bearing. In, out, up, down, side to side, it`s feels tight to me and I`ve dealt with a few bearings but never any AWD so I was wondering if it`s was something else causing the roar I`m hearing?? Something in the AWD system since this is my first AWD so I`m very unfamiliar with that type of drive train. Open for conversation with hopes of solving my problem...........
jmgldsmth
  • 2005 Answers
SOURCE: 2001 Chevrolet Cavalier front End Roar
You must replace wheel bearings in pairs to avoid loading the old bearing and, in time ruining your new bearing hub it is possible that you have already damaged the new hub
Posted on Apr 20, 2009
Murphybanton
  • 2004 Answers
SOURCE: Pronounced noise as car slows down, tire thread? or wheel bearing on RAV4 1999
It is a wheel bearing issue. consider servicing your wheels and brakes.
Posted on May 26, 2009
ourhowse
  • 2007 Answers
SOURCE: 1995 Toyota Rav4 4X4 - replace rear hub bearings
You have to take the rear diff apart to pull the axle. I think you should inspect your u-joints by taking them apart. Some times they can fool you. And check that there is no play in the pinion when you have the driveshaft off.
Posted on Jun 05, 2009
honeymokey
  • 3113 Answers
SOURCE: Cutlass Supreme new front wheel bearing repeatedly goes out
You may have pulled the inner tri-pod joint out of the cv shaft and that will make noise. Is the bearing really bad? Does it turn freely?
Posted on Jun 23, 2009
johnjnail
  • 1702 Answers
SOURCE: I have replaced the front passenger side wheel hub
it is most likely a bad wheel bearing, but it maybe the other side, some times the noise will carry threw the front end and make you think is the other side, we have a rule in my shop we never replace one wheel bearing we alwise replace both bearing on the end we are working on if the customer does not want that then we send them to another shop, the reason we do this is for just the thing you have going on it just saves allot of problems, and we never use cheep hubs, never use auto-zone or advanced or O'rileys, we had to warranty 12 hubs from auto zone in one year, i have never had to warranty a napa hub in 25 years, it just does not pay to save a few dollars. and all though it most likely is a wheel bearing there is a small chance it might be a carrier bearing in the front differential it would also go away when going around a corner but if you remove the wheel bearing and turn them by hand you can feal if the bearing has a bad spot. if the bearings feal good then pull the front differential.....GOOD LUCK
Posted on Mar 13, 2011
I think the hub assembly, front passenger's side , in my 2011 Rav4 AWD Limited is going bad because of the roaring it`s making. This is my first AWD anything so I`m a little unsure if it is really the...
simple answer is to take it to an accredited service center and have it properly diagnosed and get a quote
That way you will know what you are dealing with
Feb 01, 2018 | Office Equipment & Supplies
Rav4 2002 humming soung at rear driver side tire
Can't say or guess
I could type all the items you suggest
Have to take it apart & get involved, to
confirm, after a road test
Mar 02, 2013 | 2002 Toyota RAV4
Does the wheel bearings ever need replaced on a 1999 toyota rav4 ? if so how do you replace the driver side wheel bearing?
YOU NEED ARBOR PRESS TO REMOVE INNER RACE FROM THE HUB.YOU NEED SEAL REMOVER TOOL SST 09308-00010 YOU NEED SNAP RING PLIERS YOU NEED BEARING DRIVER DRIVE BEARING FROM THE STEERING KNUCKLE.THE CHEAPER ROUTE IS TO BUY WHEEL BEARING AT A AUTO PARTS STORE THAT IT TO A SHOP THAT DOES BRAKES AND FRONT AND REAR SUSPENSION WORK.BUY THE TOOLS GOING COST.
Oct 20, 2010 | 1999 Toyota RAV4
Toyota RAV 4 awd 1996 how do i refill the front diff
Take of the right or left side wheel and you will see a small dipstick for the diff
Jan 13, 2010 | 1997 Toyota RAV4
Jun 05, 2009 | 1996 Toyota RAV4
May 26, 2009 | 1999 Toyota RAV4
Wheel bearing installation
Unless you have the proper tools, specifically a large bearing puller, and a press, you would be best advised to take the spindle off, and take it to a machine shop. If you do not have the proper tools, you may damage the hub. very expensive part to replace.
Jan 15, 2009 | 1996 Toyota RAV4
290 people viewed this question
k24674
jasbo
jasbo
