Hi Mike, I have a Siemens IQ300 dishwasher number
Hi Mike, I have a Siemens IQ300 dishwasher number SN26M230GB/28. It is showing error E:21. The last run of the washer was successful prior to the fault. There is no water in the bottom of the dishwasher. I have removed the pump impeller cover (white) and there appears to be no blockage. When I start the dishwasher the programme starts and I can hear the pump working. No other action takes place and the error code then shows. Can you help at all? Thanks.
  • Dave Hillier
    Dave Hillier Feb 07, 2014
    I have exactly the same machine and error 21 fault too. The program starts but there is a strange graunching noise thene the error code shows. No water is going into the machine.
  • 641 Answers
SOURCE: error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Posted on Jun 27, 2006
Rotu
  • 175 Answers
SOURCE: Asko D3330 F2
there is water in the pan below the unit. You will need to take apart the lower section of the dishwasher behind the toe kick and suck out the water, or just wait for it to evaporate (few days) Good Luck!
Posted on Nov 06, 2007
  • 54 Answers
SOURCE: AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
Posted on Feb 14, 2008
  • 4 Answers
SOURCE: Diplomat ADP8322 problem
I had the same problem. its apparently due to a sensor that thinks the overflow tray (in the very bottom) has water in it..... I checked, and mine didn't....... but I found that putting the machine on a pre-wash, then doing the main wash worked everytime.....
Hope this helps
Posted on May 07, 2008
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
Washing machine error codes
Contact manufacturer or service agent
Aug 11, 2014 | Siemens iQ300 SN26M653GB Full-size...
Siemens faults
Assuming the inlet valve and hose and supply is OK and its filling with water....e14 is..
Flow fault or flow sensor fault, could be a poor connection on the sensor to the water matrix or less likely a blockage in the matrix.
Also check all inner for cleanliness and debris.
Aug 06, 2014 | Dishwashers
Error code E:14 Siemens Dishwasher - stops after 1 min of cycle
It might be helpful if you provide the full model number of the Siemens dishwasher. Most likely E14 error has something to do with water flow sensing. Check if your mains water pressure is ok (tap under sink is fully open). But can provide more details only if you can tell me the model number.
Apr 03, 2014 | Siemens Dishwashers
Our siemens WD12D520GB [iq300 washer dryer] often stops drying after 7 minutes. running a diagnostic test [6 o clock, hold spin rpm, clockwise 1 notch, release spin rpm button] gave f08. repeating the...
This info should be on the insert hidden somewhere in the machine..look behind the lower kick panel..under the lid...on back...somewhere for the folded paper insert.
Theses are Error coder specific for this manufacturer.
Oct 16, 2013 | Siemens WTXD8300 Electric Dryer
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Mar 27, 2013 | Washing Machines
How to open the door of the siemens iQ300 washing machine
This problem has nothing to do with water in the machine. My IQ300 regularly refuses to open on the drying cycle! You have to open the small round compartment beneath the door and pull down on the black plastic strap to the right - you may need a utensil to pry it out. What a rubbish machine.
May 29, 2011 | Siemens WIQ1633 Front Load Washer
 Grubhead
Grubhead
