Question about Maytag Dishwashers
Maytag dishwasher MDBH979AWW3. Clean light flashes seven times, pauses, then flashes seven times continuously. Cleaned door latch contacts but didn't help. Also turned off power for ten minutes but didn't help. I'm assuming this is some code. Any ideas??
  • 65 Answers
SOURCE: Whirlpool dishwasher not working
igsanders.. that is a heater fault code. toggle between heated dry and normal until all light light up . press cancel. now ensure door closes without striking cabinet and the unit is level. this fault normally has nothing to do with the heater but rather the nuetral to the door switch which it shares with the heater.it will now operate again.
Posted on Feb 16, 2008
  • 58 Answers
SOURCE: Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Posted on Jan 09, 2009
  • 188 Answers
SOURCE: clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
SOURCE: ''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Posted on Jun 16, 2009
SOURCE: my dishwasher clean light keeps flashing ...
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
Posted on Jan 05, 2010
Clean light blinks, dishwasher won't run.
It is telling you that it needs to be cleaned. Remove and clean all filters.
If still a problem contact manufacturer. Most people think that a "cleaning" machine won't get dirty but they do, as bits of food etc get circulated and build up on the filters. These have to be cleaned every now and then.
Aug 10, 2014 | Maytag MDB8959AWS - MaytagR JetcleanR Plus...
Maytag quiet series 200 dishwasher won't start
I had a similar problem. Turn off the power to the dishwasher. Open the door and remove the screws on the back that holds the door together. Now, locate the black control module and remove the cover. Look down at the bottom left of the control module and you should see a ribbon cable. This is the cable that connects the door keypad to the control module. Unplug the ribbon cable and the plug it back in. On my unit the ribbon cable was not making good contact and only half of the keypad was operational,
Hope This Helps !!
James D.
Jul 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Clean light blinks 7 times continuously
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. Let it go through the diagnostic to test the function of the element.(1-2 minutes). When it finishes, open the door and touch the element to see if it is hot (be careful, it can get pretty hot so wet your fingers to avoid burns).
Once the diagnostic has cleared, you should be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
May 04, 2009 | Kenmore Dishwashers
Clean light flashes constanly. Won't clear out to start new cycle
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Washing light flashes a short time after starting a cycle on a Kenmore Dishwasher model number 587.15182400
Problem was the live side contact on the door switch, with the door shut the neutral side (white wires) were shorted but the live side (black wires) were open. I removed the complete module and discovered that the actual contacts were removable, lift a single catch and slide out. Contacts were cleaned with abrasive and now all is OK. However, this is a short term fix only, already damaged contacts will continue to degrade and give trouble. Does anybody know if the contacts can be purchased or do you have to buy the complete door latch module?
Tim
Dec 07, 2008 | Dishwashers
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
-high temp wash
-heated dry
-high temp wash
-heated dry
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry, Hi Temp Wash.
If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
All lights should illuminate then a diagnostic sequence will start.
Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Jun 21, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool du1055xtpt4
Jun 21, 2008 | Whirlpool 24 in. DU1100XTPS Built-in...
Clean light is blinking
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry.
Jun 15, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 16039 - "Clean" light is flashing & dishwasher won't start
Jun 15, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
35 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
