Question about Makita GA4530 4 1/2" Grinder
Bad bearing on makita ga4530. How do I get to the upper bearing?
  • Edward Hooper Oct 13, 2013
    I need to replace the upper bearing on the head section of the armature. I can see in the breakdown there is a snap ring securing this armature into the head assembly but no clue how to get to that ring. the fan of the armature blocks this.
  • Makita Master
  • 885 Answers
You have to take the gear housing apart, remove the hex-nut and spiral bevel gear on the end of the armature so you can pull the armature out of the bearing. Then remove the retaining ring, o-ring and bad bearing for replacement.
Posted on Apr 28, 2014
My Makita "GA9020 9"" Angle Grinder has started to vibrate really bad.there seems to be play in the spindal.its used for floor sanding.i was thinking maybe bottom bearing,but just guessing any ideas thanks
Vibrations and excessive play could be caused by one of two or both bearings in the gear housing or the spiral bevel gears. Armature bearings can cause vibrations but usually don't show up as play at the spindle. Also, if the vibration is really bad, you could have several fan blades broke off one side of the armature fan throwing off the balance.
Oct 09, 2013 | Makita "GA9020 9"" Angle Grinder- 15 AMP-...
Makita Impact Driver BDT 140 problem
Overheating is usually caused by bad bearings on the front and/or back of the armature. The bearings should spin very freely and the armature should not touch the magnet at all. If one or both bearings overheated it is possible they cooked the lightweight grease out of them and froze up. Another thing to look at is the place where the bearings rest in the housing. If they are melted or deformed causing the armature to rub against the magnet they'll cause a build up of heat and loss of power. If the bearings are bad you have to replace the armature, if the bearing mounts are deformed you have to replace the housing set and armature depending on how much damage was done by the overheating.
Jan 23, 2012 | Makita 18V LXT Lithium - Ion Cordless...
My makita 4"X24" sander makes
http://www.ereplacementparts.com/makita-9404-belt-sander-parts-c-97_103_535.html
I would say you have a bearing going out ether on the motor this web address will take you to a good break down of the housing I would say you need a motor bearing it will also give you a parts # but if you have a bearing supplier somewhere ( I look in yellow pages for electrical motor repair) you might find the bearing for a cheaper price just remember to take the old one with you so you are sure to get the same size. I have found bearing and belts for my table saws are the same as for some clothes washers for about 1/2 the price as ordering from sears
good luck
Pat
Oct 29, 2010 | Makita 9404 4'' x 24'' Belt Sander
My 24v new makita drill doesnt hold charge
the new batteries now have a little computer in them, so to speak. when you plug in the battery to the charger and you get the alternate flashing light the battery is bad. if the charger is working and the battery is just not lasting very long the battery may be going bad. there could be a problem in the motor causing your battery to drain too fast. does the drill work normal, no overheating or noise, bad bearing.
Apr 18, 2010 | Makita 6408K 3/8" Variable Speed,...
Makita 9901--How to remove and replace motor bearings
Do you have a bearing splitter? If so I have used one and then gently tapped the end of the shaft to remove the bearing. The rubber pins fit into holes next to the bearing bore in the housing. You can use a vise and a soft hammer to tap the bearings on. Put the bearing on the vise and tap the opposite end of the shaft. You are on the right track for all these methods.
Nov 13, 2009 | Makita 9901 3 inch x 21 inch Belt Sander...
I CAN'T GET A BEARING OF MY SAW
Which bearing we talking about. The spindle bearing has a retainer that screws into the hub the other bearings just need pulled off with a bearing puller. Let me know
Feb 25, 2009 | Makita 5620DWD Cordless Circular Saws
Makita LS1013 chop saw just started making a bad bearing noise and the elecric brake is not kicking in after the trigger is released.
You will have to check if it is a bearing going and the electric brake may not be getting any power to it now or it could be sticking.
Jan 23, 2009 | Makita 10" Miter Saw LS1030N
Makita 5010 will not work in random orbital mode
It sounds like the bearing in thee bottom plate is seizing. If you turn the pad by hand does the motor turn. It should be smooth. I would look at that. The bearing number for Makita is 211236-8 or if you can get a generic bearing it is 6002DDW. Let me know
Jan 11, 2009 | Makita Tools & Hardware - Others
Makita GA4530 4 1/2" Grinder Logo
117 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
