Question about GE Built-In 24" Double Electric Wall Oven
Built oven jrp14g00b6 prepare oven for cleaning however oven will not start. please help
Ge profile model jcs968skss will not start the cleaning process.
Seems to me you have a relay problem on your control board .you can also have a loose connection to the board in the cleaning cycle side. Bye
Feb 27, 2016 | GE Ovens
How do I clean my Frigidaire electric oven, Model FEF352AWF?
See page 13 for specific instructions.
ShopYourWay FRIGIDAIRE Free Standing Electric ShopYourWay
As tedious as it may seem I suggest that cleaning the unit by hand is the preferred process. Most failures that I have experienced have occurred just after the clean cycle is completed. There is a lot of stress during self clean and critical components are stressed and are more likely to fail. On two occasions I have had a failure days before family dinners. Usually in preparation for family we had been cleaning the oven. Both the temperature sensor and heating element have failed.
With a free standing oven repairs are a lot easier than with a built in wall oven requiring saw horses to remove and set. In any case plan to clean long before company in the event a repair results.
Why You Should Almost Never Use Your Oven Self Cleaning Function
Jan 06, 2016 | Frigidaire 30" Self-Cleaning Freestanding...
I have a gas oven ~ not sure of the age. I
clean around your pilot light, there may be gunk built up around it.
Sep 27, 2009 | Kenmore Ovens
How do I start the clean cycle
The "S" in the model number stands for standard clean oven (vs. self clean), so unfortunately, you will have to use a can of Easy Off or similar oven cleaner.
May 07, 2009 | GE 24" Built-in Single Electric Wall Oven...
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Turbo chef oven F6 ec code
Hello. There is a temperature sensor built into the control board, and the temp in that area, is getting too hot. On the back of the unit, right top, there is a cooling fan that comes on at a certain temperature, if the intake is clogged, you will get this error, clean the intake. Inside the unit may be so dirty, it may require cleaning as well. The fan itself could be bad, and does not run, then it will need replacement.
Hope that helps, and thank you.
Feb 04, 2009 | TurboChef TORNADO Electric Oven
No power and door locked after starting self cleaning cycle
Thermal fuse went out by door latch and thermal fuse on back of oven probably tripped too; once failed they need to be replaced. This is probably a job for the repairman as something caused fuse to go out in the first place; unless resolved it will recur. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | KitchenAid Architect® Series II KEBS208S...
Lost directions to use the self-cleaning feature on my oven
I have same problem. When I hit clean, the lock engages and the oven acts like it is preparing to clean and then everything stops.
Jun 23, 2008 | Maytag CWG3600A Gas Single Oven
Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
GE Built-In 24" Double Electric Wall Oven Logo
19 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
