Question about Music
Behringer eurorack ub1622fx pro schematic - Music
  • 5603 Answers
SOURCE: Need Behringer Eurorack mixer power supply connector
Those were used for mic connectors at one time,,, they are related to the Amp 91-MC3F family of connectors and those are out of production and they are demanding $20 to $50 for one connector.
That is a ridiculous price and I would be tempted to swap out the connector for a more available design.
On eBay item 250401122616 is one but they want $13 pus $11 shipping which is a rip off.
These were used on some OLD CD radio mics.
Posted on Dec 15, 2009
Obbie15
  • 4 Answers
SOURCE: how can i connect a behringer eurorack to a mbox 2
basic speaker cable from the eurobacks speaker output to the di selection on mbox... in one of the input slots
Posted on Feb 11, 2010
  • 5603 Answers
SOURCE: Power supply cooked
There isn't anything in the power supply you cannot rebuild except the transformer.
BUT you should verify that something in the mixer didn't short out and damage the supply.
After you relace the smoked parts (likely the TOP245Y offline regulator chip is gonzo... then you use this trick to restart the unit safely:
Put a 60 Watt light bulb in series with the hot side of the input power line. I would recommend you use an ISOLATION transformer when working on the power line side of this for safety.
Posted on Apr 26, 2010
  • 5603 Answers
SOURCE: LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Posted on Apr 28, 2010
c1apton15
  • 3400 Answers
SOURCE: Where can I get a power cord for a Behringer
Any Guitar Center
Posted on Apr 11, 2011
Pdf manual by ub2442fx-pro
You can download from here... http://www.behringer.com/EN/Products/UB2442FX-PRO.aspx
Sep 30, 2014 | Behringer EURORACK UB2442FX PRO Mixer
I need a new fx push knob for eurorack ub2442fx pro
This place has a great selection of Behringer parts. You should be able to find your knob here: http://www.dbmproaudio.com/behrparts.html
Jan 10, 2013 | Behringer EURORACK UB2442FX PRO Mixer
My EURORACK UB2442FX-PRO has audio coming in but nothing coming out...
The outputs of these mixer needs to be connected to an active speaker.
An active speaker have an amplifier and a preamplifier.
Oct 02, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
I'm looking for a solution how can i connect my
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
Jun 10, 2011 | Behringer EURORACK UB2442FX PRO Mixer
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How can i connect a behringer eurorack to a mbox 2 for protools
Jan 15, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Music Logo
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
