Question about GE 1.7 cu ft Over-the-RanMicrowave Stainless Steel LVM1750SPSS
GE 1.7 cu ft over the range microwave model LVM1750SPSS. 1.5 years old. Loose wire caused complete power failure in the past. GE Technician reconnected loose wire and fixed the issue. Now the same problem happened again. Where is this loose wire so I can fix it myself?
Illeagle
  • 525 Answers
SOURCE: Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Posted on Jun 03, 2008
  • 686 Answers
SOURCE: F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Posted on Apr 08, 2009
localwonder
  • 6784 Answers
SOURCE: no power. outlets is fine. please help. thanx
This will occur if the inverter has experienced a surge or, if the cut off fuse has blown. you can check the cut-off fuse by removing the cover. it is located near the magnetron tube. replace it if it is blown. if the fuse is ok, this will confirm inverter failure. replace the inverter in this case.
Posted on Aug 29, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: I have a GE microwave
Sorry to read about your problem, I hope this helps you out.
sounds like you may have a defective magnetron, or another failure. due to the age and parts availability. you may think about a new unit.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
  • 65 Answers
SOURCE: my GE microwave (model# JNM1541DN1BB)
HELLO.
The GE problem is with the magnetron being to close to the computer. If your microwave runs for a few seconds to minutes then resets with funny characters on the screen, you can follow these simple instructions to fix it.
needed things.
* Phillips screwdriver
* Foil
* Large ziplock baggie
* Tape
* 1 Unscrew the 2 screws in the top vent grill and remove it.
* 2 Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
* 3 Put a sheet of foil into the large ziplock bag and seal it up.
* 4 Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
* 5 Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
the way to keep it from happening again is to use the microwave with more caution.
Willing to help to help on other problems.
Thanks.
Posted on Oct 01, 2011
I need to replace my over the range GE microwave Model # JVM1330WW002 and don't know what size/capacity it is?
Get cubic foot size by multiplying height x width x depth.
Divide that by 1728. If oven is 12 x 12 x 12 then it's exactly 1 cubic ft.
If 6 x 6 x 6 then it's 1/2 cubic ft or. 50 cu ft
Nov 28, 2014 | GE Microwave Ovens
Microwave starts by itself
Likely a microprocessor/control panel issue. Microwave ovens that sit over ranges often have electronic failures due to heat, humidity, and grease, from the range below, which come into contact with their main circuit boards.
Apr 16, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
What is the Power of model GE Microwave JVM1631BJ03?
The GE JVM1631BJ03 microwave is a 1000 W unit. Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/6073/GE-Microwave-Hood-Combo-L0523009 .
I hope this helps.
Apr 25, 2013 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
No power. outlets is fine. please help. thanx GE Spacemaker® 1.7 Cu. Ft. Over-the-Range Microwave Oven Model # JVM1740DMCC
Aug 29, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
Is the 1.1 cu ft 1100 Watt model: jes 1139bl sold by Home Depot the same as the 1.1 cu ft 1100 watt model sold by Lowes ? If so, what is the model number of the lowes unit ?
A quick check of the Lowe's Web site show the following GE 1.1 cubic foot microwave models:
JES1142SJ
JES1139WL
JES1139BL
JE1160WD
JE1160BD
If you still have any doubt, I'd call Lowes.
Aug 23, 2008 | GE Microwave Ovens
GE 1.7 cu ft Over-the-RanMicrowave Stainless Steel LVM1750SPSS Logo
51 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
