Question about Canon imagePROGRAF W8400 InkJet Printer
W8400 when powered on goes to initializing
And does nothing else, no fan motor or movement or anything, just stays on initializing
How do I change the bushings on lasko wind machine type 20 (maybe a 3300) fan?
Can you check to see if there is power getting all the way to the motor? Can you send me the model no.?
Carl
May 09, 2015 | Lasko Dryers
Carrier 38YRA 042 Fan Motor Problem?
plz check if there is anything obstructing the fan movement.if not then the motor is the culprit.
It will be better if you leave it for professional
Jun 07, 2008 | Carrier 38CKC042 Air Conditioner
HP Designjet 130 not initializing...
If there a jetdirect network card trying removing it and restarting.
Nov 11, 2014 | HP HEWLETT PACKARD Designjet 130 printer...
Casablanca fan intelli touch
there is a starter solenoid inside it works the speed setting. controls speed 1-2-3. 4 it bypasses it. in side the fan you will see a black box with c66 somthing that will need to be changed as that is the part that controls the speed.
Oct 17, 2013 | Dryers
Drum will not spin. Suspect something (coins) may have been left in pocket. Spin cycle goes to start but just stops.
Possible these object woul dhave got logged into the shaft or the gaps within and thereby made the movement tight. The program controller initiates the motor but since the mechanism is jammed the motor is tripped. So use a multimeter to check the motor , the voltage to the motor so as to confirm . If so remove the assembly to reset. Check manually with the hand - power disconnected- till there is free movement.
May 02, 2011 | Washing Machines
Have a new balance 1400 treadmill. when i power it on the screen goes blue and it will not doing anything.
Does the screen turn on (blue) and then go black or does it stay blue? Mine has a similar problem where when the main power switch is flipped, it lights up, shows the initialization screen, then goes dark. Pressing any button on the console does nothing. I opened the console up and suspect one programmable microcontroller is bad. I'm going to see if I can get that part from FitnessQuest instead of replacing the whole board.
Aug 28, 2010 | New Balance 1400 Treadmill
I was about to start printing when the printhead gave a strange loud voice and got th E02E01 error code. Can you help me? thanks, Rita
E02D0B Cap sensor cannot detect rotation flag
E02E01 Cannot move carriage
E02E05 Carriage movement timeout
E02E06 Printer error (Carriage motor hardware
Sounds like something is blocking the carriage.
Jun 06, 2010 | Canon imagePROGRAF W8400 InkJet Printer
W8400- gets stuck on power up with: "offline - nozzle check" stays that way for hours.
hello mike.
i have the same problem!
Can you tell me if you find a solution for this?
thank you!
Oct 09, 2009 | Canon imagePROGRAF W8400 Printer
Can i put a dimmer switch on a floor fan? i just bought an industrial-type floor fan, but i don't need that much air movement all the time, how could i wire up a dimmer or potentiometer so that i could...
A potentiometer would overheat because when you tell it to turn the power down, it basically just runs the extra power through a heating element, which will probably catch it on fire for something that large. A dimmer switch changes the voltage that goes in, and is generally meant for incandescent lights. If you wired a regular old dimmer switch up, the motor would probably sound weird, and the dimmer switch or motor would break, possibly starting a fire. It's illegal to use a regular light dimmer switch on anything but an incandescent light socket. However, you can easily find a controller that will work. Look for a fan speed controller or motor speed controller. Make sure it's rated for the correct voltage and has an amp rating not exceeded by the fan's rating. These look like a dimmer switch but are designed to deliver the power the motor needs. See link http://www.lowes.com/lowes/lkn?action=productDetail&productId=70801-539-SFSQ-FH-IV&lpage=none
Sep 17, 2009 | Global Product Resources Deco Breeze...
LG 47LC7DF LCD TV turns off with a pop then turns back on.
Sounds like a overheating issue. Try facing a large fan blowing across the back of the unit and see if this changes anything. If it does, it might help to blow the back out with compressed air as dust might be helping it overheat.
Aug 08, 2009 | LG 47LC7DF 47 in. LCD HDTV
Canon imagePROGRAF  W8400 InkJet Printer Logo
24 people viewed this question
old marine
old marine
