Question about Electrolux Washing Machines
Electrolux EWF 14780 unable to warm up water. The machine will start for about 5 minutes, then when the screen display with the wash temperature shows that it is to start warming up the water, machine just stops and gives a normal beep signal to indicate completion of washing process. No error codes. Cold water stays in. I had tried a wash cycle with cold water, machine just washed like normal. This problem started after I did a thorough clean of the machine with a half cup bleach at 90 degrees celsius yesterday morning with no laundry, followed by another full wash of kitchen towels at 90 degrees later part of the day. The machine is 5 years old, has always worked good, until I gave it a thorough clean. Whoever has a solution for me, thank you very much.
  • clearyroel
    clearyroel Oct 13, 2013
    My problem is fixed by my husband. By pressing the two buttons from the right, we got an error code E66 which means fault on PCB. The green board behind the control panel has a bad soldering of the relay. One corner has came lose. Once the relay has been soldered back, the washing machine can warm up water like it should be.
zaids
  • 456 Answers
SOURCE: cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Posted on Apr 12, 2008
  • 1294 Answers
SOURCE: No movement, then loud beeping alert
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 10, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
BNewberry
  • 93 Answers
SOURCE: water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Posted on Jan 12, 2009
  • 174 Answers
SOURCE: A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Posted on Jul 24, 2010
How do I fix this problem: The OK light flashes. The washing machine worked for an hour but then this problem happened.
Obviously, an alarm is displayed after some time.
The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
• button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
• button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
Dado
Jun 10, 2016 | Electrolux Washing Machines
Why wont my ewf 1080 electrolux spin
Most likely the washing machine is stuck in Hold mode. Check if you have the spin speed knob at the correct setting.
Manual is available from here
http://www.manualslib.com/manual/616814/Electrolux-Ewf-1080.html#manual
Check the parts and schematics at this site
http://spares.bigwarehouse.com.au/index.php?cPath=64689_77309_77544&sort=2a&page=1
Aug 29, 2014 | Electrolux Washing Machines
Door locked
Try turning the main power off at the socket for 5 mins - the door may open then , if not turn the power back on and see what happens.
i had this problem on an Electrolux and it worked.
Jan 22, 2014 | Washing Machines
Our electrolux front loader Washing Machine EWF 1083 won't fill with water and there is a humming sound, does anyone know what the problem is ? cheers
Just a long shot - it may be the water inlet filter is blocked? normally there is a little mesh filter in the hose that screws onto the back - check that its not full of crap. This happened to me only a few weeks ago hope its as simple as that for you.
Jan 20, 2013 | Washing Machines
Jul 24, 2010 | Electrolux Washing Machines
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Aug 08, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
