Question about Car Audio & Video
Output speaker ground post is hot has power coming from it why just got this jeep and the amp was already installed what would cause the neg post of the speaker to be hot lights out my 12 volts tester light please help system sounds like crap
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Post a pic please.
Posted on Nov 15, 2013
How to bridge a subwoofer
Ok when you have 2 subs, bridging is when you use the power from one of the outputs an the amp into a sub, and the neg of that sb to the positive of the next sub, and the ground from the second sub back to the amps ground but on the other output set.
Feb 23, 2013 | Car Audio & Video
Wiring diagram pioneer dxt-2369ub
----POWER---
Yellow = Radio Constant 12V Batt +
Red = Radio Switched 12V Acc +
Black = Radio Ground Neg -
Blue/wht = Remote Amp turn on or Pwr Ant
----SPEAKERS----
White = Left Front Speaker Wire (+)
White/blk = Left Front Speaker Wire (-)
Grey = Right Front Speaker Wire (+)
Grey/blk = Right Front Speaker Wire (-)
Green = Left Rear Speaker Wire (+)
Green/blk = Left Rear Speaker Wire (-)
Purple = Right Rear Speaker Wire (+)
Purple/blk = Right Rear Speaker Wire (-)
RCA = Output to Amp
Nov 30, 2011 | Car Audio & Video
I have an urban audio works 7 band equalizer. i have a spx pro audio amplifier and an alpine cd reciever model cde987. the equalizer is not installed. could your please tell me where to wire in the blue,...
INPUT: Yellow (left front), violet (left neg), green (left rear), Blue (right rear), Brown (right neg), Gray (right front)
OUTPUT: Front Left pos (green/red) neg (green), Front Right pos (gray/red) neg (gray), Left Rear neg (brown) pos (brown/red), Right Rear neg (white) pos (white/red)
dfsanchez@yahoo.com
Mar 14, 2011 | Car Audio & Video
Hi there, I bought a 2007 electra glide fairing w / harmon kardon radio . Which wires on the 23 pin harness do i use for power,ground, & speakers. I have a 99 Kawasaki Nomad 1500 that i installed...
If it is the basic radio then here are the wiring pins for it:
RT FT Speaker - Pin 18
RT FT Speaker + Pin 1
LFT FT Speaker + Pin 16
LFT RR Speaker - Pin 17
Power and Neg pins are Battery Pin 10, Ground Pin 11
Ignition Pin 12
Another Power & Neg pins are Battery Pin 19, Battery Pin 20
These are the Pin Connectors for the stereo.
Mar 14, 2011 | Harley Davidson FLHTCUI Electra Glide...
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
There is a engine noise coming out from my speakers
(1) If you have an ohm meter check from neg terminal of battery to body of your car. It should be below 1 ohm. You should get the same reading between the amp neg terminal and the amp ground point. Check amp ground with the power off and the wire to the negative on the amp temporarily disconnected. Most cars have a braided uninsulated ground strap from the engine to the body or frame. In older cars this can break and it usually causes noise. Run a temp ground wire from the battery neg to the bat neg of your amp, if the noise goes away it's a ground issue for sure.
(2) Make sure the amp is well grounded ! The bolts that anchor the seats to the floor are one of the best ground points I know of.
(3) I've fixed a few amps that had an internal broken connection from the RCA's on the amp where they connect to the circuit board. This often happens from not having the amp bolted down and/or the RCA's getting hit or kicked. This will cause noise in the amp and requires taking the amp apart to fix it.
Apr 02, 2010 | Solid Audio Formula Series F4 4-Channel...
My amp suddenly stopped working. Orion-Cobalt 800.1 RCA Problems.
Hello icpdownie,
A grounded or shorted RCA cable could be the problem. Try replacing the RCA's.
Hope this helps.
Aug 12, 2009 | Car Audio & Video
My amp gets really hot as soon as the power comes on. what does that mean
Check your speaker output cable and connector, they might have connected to body of car.
  1. Remove all input / output cable from amp
  2. Plug the power into amp.
  3. if still the amp is still heating.
  4. Check if any screw used to fix is not connected any part of the amp output or input point.
Jul 22, 2009 | Kenwood KAC-728S Car Audio Amplifier
AMP GUARD ON
I'd say go back to the guy who installed and get him to do it right. He's either left some wires exposed so they are intermittently touching, or has an open connection to one of the speakers. The amp will shut down to protect itself. He may also not have wired the speakers correctly. Some systems don't work unless both hot and ground wires run directly to each speaker. Some installers run only a hot line and use the car body for ground. At higher powers this can cause amp shutdown or keep it from working at all. In any case the installation wasn't done correctly.
Apr 22, 2009 | Clarion M475 CD Player
Diamond Audio amplifier 1200W
If the speaker wires touched and the protection circuit didn't engage quickly enough, the output transistors may have failed. This is the most common cause for an amplifier to go into protect mode.
If you disconnect the speaker wires from the amp and the B+ and remote voltage are above ~11 volts (place black meter lead on ground terminal of the amp when checking the voltage), and the protect light still comes on, the amplifier will need to be repaired.
Nov 25, 2007 | Car Audio & Video
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
