Question about TruTech T100-CD Personal CD Player
Unit powers up but I get no sound - TruTech T100-CD Personal CD Player
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
I get an error code e1 and have cleaned and replaced the filter. Runs for a couple minutes then shuts of with same message. Any ideas?
THIS SHOULD RESET IT
1 DISCONECT THE POWER PLUG FROM POWER SUPPLY 2 CLEAN FILTER 3 HOLD DOWN THE POWER ON/OF BUTON ON THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTILL IT EMITS A BEEP SOUND FOR APROX 5 SECONDS 4 DISCONECT POWER AND PLUG AGAIN
IF THAT DOES NOT WORK 1 DISCONECT UNIT 2 HOLD DOWN THE MODE KEY ON THE PAD OF THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTIL IT EMITS A BEEP SOUND APROX 3 SECONDS THE UNIT WILL START. 3 STOP THE UNITS OPERATION BY PRESING ON/OF 4 RESTART UNIT.
BEST OF LUCK
May 31, 2011 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
Camera lens will not open. power sounds normal
failure of the sensors of the lens unit and failuree of allienment of lens unit with the mother board
Feb 26, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
4 second shutoff
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem. Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over.
Jan 21, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Outside Unit blowing air but not cooling and slight buzzing sound
The compressor is not coming on and some part of that unit has failed. Do you hear any clicking sounds along with the buzzing sound? Recommend that you shut the unit down (remove power from it) until a service tech can listen to it try to start up.
The power company-installed load management system is probably a red hearing. That system will either fully turn off the unit or allow it to turn on/start up.
May 08, 2009 | Heating & Cooling
Pioneer stereo receiver has sound and power problems.
i would suggest checking the wires on the speaker switch board, thats usually the main cause of this problem..but i dont recommend buying pioneers newer stuff
May 04, 2009 | Pioneer Audio Players & Recorders
No Sound
power the unit down totally from the wall socket to allow it to reset. It may have had a processor scramble in the outage and not selecting audio inputs correctly.
Dec 08, 2007 | Pioneer VSX-D509S Receiver
Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
Sep 18, 2007 | Audio Players & Recorders
23 people viewed this question
Top TruTech Audio Players & Recorders Experts
David Payne
David Payne
Tom Chichester
Are you a TruTech Audio Player and Recorder Expert? Answer questions, earn points and help others
