Question about EnGenius ENH202 Wireless Outdoor 800mW Long-Range Multiple Client Bridge/AP
Engenius enh202 gets network connection with no problem but will not get internet access at all. network connectivity to the bridge is -52 dbm. its for my solor system connected to an enphase network box
3 Suggested Answers
Macs R We
  • 481 Answers
SOURCE: How to setup internet between 2 EnGenius EOC-2610 devices?
Thanks for a very thorough problem report. It's a little ambiguous near the end, though, so I will have to restate what I think I understand you are saying.
You are saying that you have your internet connection and AP in one building, and two devices or PCs in that building can access the internet and share files (though you don't specify if they are using the EOC-2610 access point or are just accessing the router in some other fashion). But you have a remote building where there is one PC and one EOC-2610 in Client Bridge mode, and although both EOC-2610 units seem to be communicating with each other, the PC will not communicate with anything. (I presume you have inspected the access point's configuration screens and verified that it does have the other EOC-2610 listed as a connected client.)
First, the PC in the remote building has to be connected to the Client Bridge EOC-2610 by its ethernet cable in order to access the network. Second, the PC in the remote building has to have a valid IP address in the range 192.168.0.0/24, or it won't communicate with anything. If you are relying on your router's DHCP to assign your PC an IP address, verify that this has happened by examining your PC network properties. If you are assigning all IP addresses manually, make sure you have assigned the PC an address, and one that doesn't duplicate some other device.
Sometimes failure to specify DNS servers appears to be a lack of communication with the network. Open a browser and type 66.70.119.204 in the URL bar. If you get to fixya.com, you have a good network connection. If you type fixya.com in the URL bar and can't get the same result, you need to define DNS servers on the PC (or inside your router).
Posted on Jun 17, 2010
elix0411
  • 3530 Answers
SOURCE: im trying to connect an
Welcome to Fixya
Check the wireless adapter properties of your computer. Under the TCP/IP the IP address and DNS address should set to automatic detection. Please see picture below.
Once you are connected try to ping a website ans see if you are getting reply from a website e.ge yahoo.com. click start then type CMD from the start search box then press enter. Type in ping yahoo.com from the command prompt. Please see picture below.
Please reply this email for any feedback.
Thank you for using Fixya!
Posted on Apr 09, 2011
No internet
I had exactly the same problem with my EnGenius ENS202EXT. I was trying to set up an Access Point, hard wired to a FAST1704N V1.0 Router/Modem from Windstream communications.
I spent 2 days trying/altering as many different combination settings as possible, on the Engenius. It turned out in the end that I had alter an unnecessary setting in the Fast1704 modem/router. After I reset the modem to factory settings everything worked beautifully. I have great coverage and higher speeds than I ever had before.
Note: in addition to the fact that internet would not pass through to the Access Point I was trying to set up, neither would the FAST1704N V1. show up on the internal network. I could not find or communicate to the FAST1704N V1. through my own network until I reset my modem/router. After resetting the modem and getting internet through the AP, I went back an readjusted the critical settings in the modem. Everything working great.
Oct 10, 2013 | EnGenius ENH202 Wireless Outdoor 800mW...
I cant configure the EOC 1650 using windows 7
To start set the IP in your computer to 192.168.1.21, Subnet: 255.255.255.0 don't worry about the Gateway or DNS.
Connect one end of a network cable to the network port on the bottom of the Engenius.
Connect the other end of the cable to the POE port on the power inserter.
Plug in the 24Vdc cable and power supply.
Connect another network cable to the LAN side of the power inserter and the LAN port of your computer.
Now we can try to ping the Engenius.(This is a test to see if the computer and the Engenius are able to communicate)
Go to Start on your computer.
In "Search" Type in: cmd
Click on the "cmd.exe" program.
A black box will pop up.
Type in: ping(space)192.168.1.1
You should see: Reply from 192.168.1.1: bytes:32 time:1ms ttl:52
This means you're connected to, and can communicate with the Engenius.
Your sending a request to the Engenius and It's sending a reply back.
Now open Internet Explorer.
Type in: 192.168.1.1 in the address bar at the top of the screen.(don't worry about HTTP or any of that, it's not needed)
A box will pop up asking for a username and password.
Type in admin for both and hit enter.
make sure, Windows Firewall is disable on your machine....
Please rate this , if you like
Thanks
Sandeep
Mar 09, 2011 | EnGenius EOC-2610 802.11b/g Wireless...
Do I need to change the password on this product if the password for my wireless network is changed?
I am assuming you are using it as a wireless bridge to connect wired devices to your wireless network. If that is the case, then yes. You must change your key on all wireless devices (including your bridge) if you change the key to connect to the access point.
Oct 29, 2010 | EnGenius ECB-3220
I pushed the reset button on my engenius IEEE802.11 b/g router......it isnt working now it says it is on my when i try to use it on my computer and my xbox360 it automatically says that i dont have a...
When you push the reset button, you reset the network configuration to factory default. Now you have to reconfigure the unit to re-establish the network routing and addressing for your home network, the same way you configured it when you first got it. Its default address is either 192.168.1.1 or 192.168.1.2, depending on whether it was in bridge or AP mode when you reset it.
Aug 27, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
WDS Setup
In a WDS network, all the access points need to be in WDS mode, and one of them needs to be wired directly to a routed internet connection.
Here is a very good detailed tutorial on how WDS works and how to configure and troubleshoot your own WDS network:
How To: Setting up WDS Bridging / Repeating
Jun 03, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
Mar 13, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
I am using a EnGenius Senao 3220 plus bridge radio to pick up the signal from another same brand radio. i am able to connect to the network but i was not able to get in to the internet: "Unable to get...
If you have the radio configured as a bridge (not a bridge-router), you must ensure that your computer is in the same LAN IP subnet as the remote router. If the remote router supplies DHCP, this should happen automatically; if not, you must configure your computer manually.
Once there, you may have to manually define DNS servers on your computer in order to access machines on the internet by name. If you can browse to http://216.239.122.34, but not to http://google.com, your problem is solely lack of defined DNS servers. This is not an artifact of the Engenius units, but the remote server.
Oct 31, 2008 | EnGenius EOC-3220 (EOC3220)
No connection.
You are trying to establish a point-to-point link between two buildings. You need one access point and one bridge. Technically, it doesn't matter which one you put at which end. Traditionally, you put the AP where the network connection is, because it makes adding future remote locations easier.
500 yards should be a cakewalk for this model.
Aug 07, 2008 | EnGenius EL-2611CB3+ Deluxe...
After a windy day lost wireless connection
For a new unit disconnect the eoc from the network and connect directly (through POE injector of course) to your laptop/pc.  then in network connections setup your lan port TCP/IP settings as follows.  ip 192.168.1.10 subnet mask 255.255.255.0 then gateway 192.168.1.1
point your browser to 192.168.1.1 or 192.168.1.2 (one if it is in AP mode and the other address works if it is in bridge mode).
When configuring, I assign it an new static IP outside of the DHCP assignment range.
To see how it is setup afterwords you can use hyperterminal with a null modem cable to view the current config.  instructions on the engeniustech.com support page.
May 28, 2008 | EnGenius EOC-3220 (EOC3220)
EnGenius ENH202 Wireless Outdoor 800mW Long-Range Multiple Client Bridge/AP Logo
67 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
