Question about Microwave Ovens
Panasonic microwave oven model nn-h965bfx door wont close. feels like spring or something is no longer latching the door close.
    Problem Solver:
  • 9 Answers
I have the same model microwave. When I opened the thing up I noticed that the latch and safety switches are connected to the chasses with two screws. The problem with this design is the metal that holds the microwave together bends every single time you open the door over time this causes metal fatigue. The part that has to be replaced to fix this is the chasses itself. I have found a way to rig it up and work for a while. I don't know how long it will last, but it is working now. I used a little hole tape and a 1x2 piece of wood about 6" in length. Put the piece of wood on the side of the latch closest to the cooking section of the microwave. Then put the hole tape from the top lip to one screw in the latch. This seems to be keeping it from moving for now.
panasonic microwave oven model nn-h965bfx   door - f10aecfb-1c51-483b-9cc0-88557759e3b6.jpg 7025bc7f-a253-4f4f-84b1-7e1a9a9e92a4.jpg
Posted on May 17, 2014
  • Jayson Cooper
    Jayson Cooper Jul 10, 2015
    Update: It is 3 months shy of being 2 years since I have made this repair and the repair is still working. Panasonic should incorporate something like the above into their design for this unit.
MicrowaveSvc
  • 9047 Answers
SOURCE: Need door assembly diagram to
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Have a Panasonic microwave model
You can order Panasonic parts here. Chances are you'll have to order just the part that's bad, assuming it's available.
Otherwise, I would recommend that you contact your nearest Panasonic-authorized servicer to see if they have any used or "new old stock" doors or parts.
MicrowaveSvc
  • 9047 Answers
SOURCE: door does not latch close
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Posted on Sep 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: broken door catch, possible spring,
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 27, 2008
caroldon
  • 17129 Answers
SOURCE: I have a Panasonic microwave NN-V689W where the
You will need to check out from the Panasonic service centre ( try a search for this model) but the best will be to try to get a salvaged door assembly unit. Mostly many sets have their panel pads or electronic boards damaged leadding to scrapping the set. So if you can try you will be able to easily source all the reqired spares or the fully door assembly from a scrap dealer / repair shop. Also try to improvise with a latch for triggering the limit mocro switch. You can attach some plastic to be welded to the door latch so as to push the limit switch. at least for the time being or even use another limit switch with an extended stem. Hope you try this out. Good day .
Posted on Aug 11, 2010
Testimonial: "Quick response with some valid ideas. "
My Panasonic microwave nn-t945sfx. Door is hard to shut and is not latching correctly. I inspected the spring and latch and it appears to be working correctly. I noticed the two holes where the latch
Common problem. Apply a small dab of lithium grease to the tips of the door hooks. You might also have to adt. the door latch switch assembly inside the oven as it could be bent out of shape from the hard to close door.
Nov 19, 2014 | Panasonic Microwave Ovens
NN-SN778S DOOR LATCH SCHEMATIC DIADRAM
There should be tension from the spring that pulls the door hook down. If there is no tension, the anchor for the spring has broken off and the outer door frame must be replaced.
Sep 02, 2014 | Panasonic Microwave Ovens
NN-T994SFR. Inclosed light stays on and the indicator states the door is open.
It is micro switch when you close the door, the door latch push in a button on the micro switch take lid off open and close the door and see if you can spot a button not popping out properly or the latch not in line with the switch
Oct 04, 2013 | Panasonic NN-T994SF Microwave Oven
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Oct 25, 2012 | Panasonic NN-T774SF Microwave Oven
Have a Panasonic Microwave Mod. # NN-P294BF. The Door opener (push button type) became detatched from the door latch. It is mounted over the stove. Do I have to take it down to be able to take the...
Here you can find what you need for a very similar model
http://www.searspartsdirect.com/partsdirect/part-model/Panasonic-Parts/Microwave-Parts/Model-NNSD297SR/0789/0123370/50036271/00001?blt=06&prst=0&shdMod=NN-SD297SR
Yes, to take down the face you must have the unit fully accessible - the bolts are accessible only from the rear.
Apr 13, 2011 | Panasonic NN-P295SF Microwave Oven
Our panasonic inverter microwave (3 years old) needs repeated hard slams to shut the door so that the light goes off and the microwave will work. How do we fix this problem as I'm afraid we are going to...
We have a Panasonic Inverter microwave. Door became difficult to close and had to slam it hard while holding themicrowave to keep it from moving. When opening the door did not pop open but did unlatch. I ordered a new door lever from Panasonic. When got part I removed case from microwave and lever was okay. I then removed the perimeter strip on the inside of the door. With a screwdriver I stretched the spring at the bottom that keeps the door latches pulled downward. Spring still worked just not as stiff. Put perimeter piece back on the door and replaced housing (which I didn't need to remove in the first place), and then put a small drop of vegetable oil on the cams where the door latches hit when closing door. Viola, door opens and closed as new. Problem solved. Diagnosis: over time the latch tension spring hardens and gets too stiff. P.S.: I had several similar springs as backup in case I screwed up the original one.
Jan 16, 2011 | Panasonic NN-SN657SMicrowave Oven
Panasonic nnt774sf door will not remain closed. It appears the top plastic piece on the microwave itself (not on door)that the hooks latch on to is broken. Is there a way to fix this?
You can purchase parts for Panasonic microwaves but home repair is not recommended due to them being lethal if you do something wrong. I would find a good local repair shop and they should be able to find the part and repair. It might not however be cost effective, depends on the part price.
Mar 11, 2010 | Panasonic NN-T774SF Microwave Oven
Door of my microwave oven NN A524M not closing properly and hence can't use it.
If needed, you can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
You can find an authorized Panasonic servicer here.
Nov 03, 2008 | Panasonic Microwave Ovens
Door does not latch close on the Panasonic Microwave Oven Model No. NN T444SF
Aug 26, 2008 | Panasonic Microwave Ovens
Need door assembly diagram to replace door latch & spring on Panasonic microwave model nn-t964sf
Jul 23, 2008 | Microwave Ovens
Microwave Ovens Logo
399 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
