Question about EnGenius ENH202 Wireless Outdoor 800mW Long-Range Multiple Client Bridge/AP
No internet I can connect to the network itself but for some reason internet doesn't go out to it. it has full connection and if I bring my phone up there with network only for internet it works great. any idea's? tried static IP and setting up on a DMZ to try things out
    Sergeant:
  • 187 Answers
I had exactly the same problem with my EnGenius ENS202EXT. I was trying to set up an Access Point, hard wired to a FAST1704N V1.0 Router/Modem from Windstream communications.
I spent 2 days trying/altering as many different combination settings as possible, on the Engenius. It turned out in the end that I had alter an unnecessary setting in the Fast1704 modem/router. After I reset the modem to factory settings everything worked beautifully. I have great coverage and higher speeds than I ever had before.
Note: in addition to the fact that internet would not pass through to the Access Point I was trying to set up, neither would the FAST1704N V1. show up on the internal network. I could not find or communicate to the FAST1704N V1. through my own network until I reset my modem/router. After resetting the modem and getting internet through the AP, I went back an readjusted the critical settings in the modem. Everything working great.
Posted on Jun 17, 2015
My wifi stop working,i dont know why???
Solutions to Common Android WI-Fi ProblemsFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up. I usually fix their problem after few troubleshoots but today while I was fixing a problem on my device, I realized that it could happen to any one - even to my readers on Guiding Tech. Hence we are going to discuss four of the most common Android Wi-Fi problems and see the probable causes and solutions to them.
Android Cannot Scan a Wi-Fi Network Reason
There may be two reasons as to why your Android cannot scan a network automatically. The first reason may be that the network you are trying to connect to could be Ad-Hoc in nature. As most of the Android phones are not configured to work on Ad-Hoc networks but on access points, they don't scan them.
The second reason may be that the Wi-Fi network you are trying to connect to might be hidden for security reasons.
Solution
By default, Android does not support Ad-Hoc Wi-Fi network but many developers patch the wpa_supplicant file on Android in order for them to work. If you do a quick Google search you will be able to find if there's a fix available for your device but the fix can only be performed on a rooted phone. Furthermore, don't forget to back up your original wpa_supplicant file if at all your phones goes into foreclose or boot loops.
If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
Wi-Fi Keeps Disconnecting Frequently Reason
The most obvious reason for the problem may be with the Wi-Fi Sleep Policy which disconnects your Wi-Fi every time your Android goes to sleep to save your battery's juice.
Solution
To manage Wi-Fi Sleep Policy, open Advance Wi-Fi settings on Android and tap the option Keep Wi-Fi on during sleep. Here, check the option Always to enjoy an uninterrupted connectivity, but you will have to compensate it with your battery life.
If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
Obtaining IP Address Infinite Loop Reason
I don't know the exact reason behind this, but it might be a bug in Android. I have seen many people getting this problem, and it gets kind of annoying when the problem does not gets fixed even after restarting the device.
Solution
First of all, you must restart your Wi-Fi router and see if that helps. Many people say that resetting the phone to factory state works but that's not an appropriate solution. Wi-Fi Fixer is an amazing Android app that can help you here. The app resets your Wi-Fi system files (same as when you reinstall the Wi-Fi drivers in Windows, or you disable and enable the Wi-Fi adapter) and services and helps you to connect to the network and obtain the IP address.
Solutions to Common Android Wi-Fi Problems
Ads by Google
    wifi-router.pngFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up.
    Solution
    ad-network-manually.png If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
    Solution
    Ads by Google advanced-settings.pngkeep-wifi-on.png If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
    Solution
    wifi-fixer.png If you know the range of IP address the router is broadcasting, you may configure your Android to use static IP address while connecting to the network.
    Can't Connect to Internet using Wi-Fi Reasons
    There may be several reasons as to why you are not able to connect to the internet even when you are connected to the Wi-Fi. The reasons may be:
    • The router is not broadcasting internet services.
    • The IP address or the gateway is wrong.
    • Problem with the DNS settings.
    Solutions
    You may use another device to check if the router is actually broadcasting internet. Also you can configure the IP address, the gateway and DNS manually to connect as their might be problems with DHCP.
    Conclusion These are pretty much most of the Android problems one might encounter on his device and the probable solution one can try to fix the problem. I don't guarantee that you will fix the problem but it's a good start nonetheless. And most of the solutions should work actually.
Thanks .
Sep 03, 2013 | Cell Phones
Tip
How to put the Internet to an iPod
<p>Apple's iPod device only with Internet capabilities, the iPod Touch. Other versions of the device can only synchronize with a computer full of music and video. The iPod Touch, however, can connect to wireless Internet networks, where available. Bringing the Internet to your iPod Touch, you need Wi-Fi settings to activate the device. Once you allow them, the iPod Touch Wi-Fi settings will be available networks, you can connect to a tap of the finger to detect. <br /> <p><br /> <p>1. Click the Settings icon on the home screen of the iPod Touch. <br /> <p><br /> <p>2. Click Wi-Fi <br /> <p><br /> <p>3. Click "On". <br /> <p><br /> <p>4. Click a wireless network in the list that appears to connect. <br />
on Aug 05, 2011 | Computers & Internet
My KC550 lg does nt run internet .I received settings also but it give s communication error.why?
First what is a KC550 lg , laptop , deskop , mobile phone.
Im assuming phone have you synced with the wireless router ?
Connecting your LG phone to wireless Internet is easy to accomplish with phones that can receive Wi-Fi signals.
You may decide to use the Wi-Fi capabilities in the event that you do not receive the best signal from your wireless provider at your home or office.
If this is the case, then hooking up to a Wi-Fi network near you could provide you with a faster connection to the Internet and a more reliable signal to send e-mails, texts and pictures.
Press the "Applications" tab on the home screen of your phone.
Scroll down the list of applications until you reach the "Settings" option.
Press "Settings" to bring up the menu.
Locate and click the "Wireless & Network" or "Connections" option within the "Settings" menu.
Select the "Wi-Fi Setting" or "Wireless Manager" option, then select the network that you want to connect to and click "OK."
All of the available wireless networks within your range will appear.
Enter the wireless network password (usually located bottom of router) if you are connecting to a secure network.
Press the "Done" button followed by the "Connect" button.
Jul 26, 2013 | Computers & Internet
Yamaha receiver will not connect to Airplay
I have the same problem, it seems the airplay connection is easily lost, it never plays for longer than an hour without itunes losing the receiver, then i have to reset the receiver so that it appears in itunes again, very annoying. I spoke to Yamaha and they are not aware of any issues but clearly there is one. A quick workaround is to bring the receiver up in a browser by typing in its IP address, go to IP Address tab and simply apply without changing anything, this causes the receiver to initialize its network function as you will see the amp resetting and it will then appear in iTunes. This doesn't work through the units setup without changing settings and then changing them back again. Hopefully this is just a glitch that will Yamaha will fix in the next firmware update, I am running 1.14 update.
Sep 28, 2012 | Yamaha RX-V473 5.1 Channel Network AV...
Cannot connect to internet
Try these two methods below.
Method 1: Check your local connections at network and sharing center, if there are two enabled or active networks. If there is two active networks, click on Local Area Connection Link (for windows 7) on one of the active networks and disable it. Now right click the internet icon on your taskbar and troubleshoot problem. If it doesn't resolve the problem, you will have an option to resolve the problem as Administrator.
Method 2: Go to local area connection status on an active network, click properties then double click on internet protocol version 4 and make sure that "Obtain an IP address automatically" and "Obtain DNS server address automatically" are checked then click OK.
If it doesn't solve your problem. Please contact me so that I can assist you more further.
Sep 12, 2012 | Sony Ericsson XPERIA X10 Cell Phone
Cant get internet on my itouch from my X3 via bluetooth
first of all get the latest software. i think the latest one is ovi and not the nokia pc suiteafter having it make sure you are using the correct settings in your mobile then try to connect itif it doesn't connect call your customer care and tell themthere are few networks for which the settings in ovi must be entered manuallyas you have not provided your service provider name i cant help you out much
Nov 24, 2011 | Nokia X3 Cell Phone
The internet connection in my area went down yesterday, but i didn't know this and thought the reason i couldn't access internet was a problem with my linksys wrt54g router. So i unplugged and...
The first thing you should do is a proper 'powercycle' for all of your internet equipment.
To do this:
1) Unplug the power to your modem and your router, and power off your computer.
2) Wait a full minute.
3) Plug the power back in to JUST the modem.
4) Wait some more - for the modem to fully connect to your ISP, and the lights to indicate. If you're not sure, just wait about 2-3 minutes.
5) Plug the power back into the router.
6) Wait another minute or two for the router to finish connecting.
7) Then turn the computer back on.
You can bypass the computer turning on and off if you can repair your wireless connection.
If this doesn't work, there is a pinhole sized reset button on the router itself that you will need a toothpick or somesuch to press - press and hold the button for 5 seconds, and then try the steps above again. If you do this, the network id and password will be reset to the default, just like it was when you bought it.
Jul 20, 2011 | Linksys Wireless-G WRT54G Router
AOL Dial up on Windows 7
Click on the Network Connection icon in the bottom-right hand corner of the start menu (next to the system clock). This will bring up the Network Connection window. Depending on how your computer is set up, it may look like either of the icons below:
Click Open Network and Sharing Center at the bottom of the Network Connection window.
Click Set up a new connection or network in the Network and Sharing Center.8896771.jpeg
Select Connect using a dial-up modem and click Next.
On the Type the information from your Internet service provider (ISP) screen, enter the details as follows:
a) Dial-up phone number: 0198308333
b) User name: Your full Westnet username. This will generally be in the format of yourusername@westnet.com.au, or sometimes yourusername@wn.com.au.
c) Password: Enter your Westnet password. This is case-sensitive, so ensure your caps lock key is switched off and you are entering your password in the correct case.
d) Connection name: It is recommended you change this to Westnet Dial-up Connection.
e) Allow other people to use this connection: If you have other Windows user accounts on this computer, and you intend for them to be able to use this dial up connection, check the box. Otherwise, leave it unchecked.
f) Ensure you have connected your modem to the phone socket, and click Connect. This will automatically attempt to test the new connection by dialing up to the internet.
To reconnect to this dial-up connection in the future, click the Network Connection icon in the bottom-right hand corner of the start menu, click Westnet Dial-up Connection, and then click the connection button.
Jun 24, 2010 | E-Machines eMachines Desktop PC
IPod touch Digital Media Player: i have an ipod touch and it claims i have full int...
This is most likely a problem with the internet connection itself. There are a few things you might need to check. First, an iPod touch will usually only work on a Channel 6 internet connection, though it can connect to other channels. Second, you should make sure that there is an internet connection with the wireless network, and that it's not local only, but instead local and internet.
May 17, 2010 | Apple iPod touch
Cant connect to vodaphone uk from my LG prada phone!help!!
i have the prada lg and for some reason cant connect to internet..not sure if one of my kids have tampered with the settings.. says network failed. please help!!!! thanks ruth
Sep 04, 2009 | LG Prada KE850 Cellular Phone
EnGenius ENH202 Wireless Outdoor 800mW Long-Range Multiple Client Bridge/AP Logo
390 people viewed this question
Top EnGenius Computers & Internet Experts
Michael Vincent Cruz
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
