Question about Tricity Bendix Washing Machines
Tricity Bendix tbwd 1210 So my problem is that
Tricity Bendix tbwd 1210 So my problem is that start/pause buttom is flashing and even when i am pressing nothing happens no matter what program i try to turn on is not working start buttom keeps flashing i tryed to find error code the code is E51 i need help soon :)
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
  • 1294 Answers
SOURCE: zanussi jet system 1200
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Press "end of cycle" to finish the mid stoppage..
Rate me pl.....if helped.
Posted on Jan 02, 2008
SOURCE: tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Posted on Feb 26, 2008
  • 135 Answers
SOURCE: manual for tricity bendix 1000
Please try here:
http://www.serviceforce.co.uk/pdfs/U23248.pdf
If this is your model (there are 5 models with the same name) please rate my response.
If not, please let me know and I will find the link for your model.
Thanks.
Posted on Feb 24, 2009
Change brush on tbwd 1210
unplug machine
take of rear panel
take of belt
remove motor
remove old carbons and replace
Jan 09, 2014 | Tricity Bendix Washing Machines
Washing Machine will not start
either your door actuator is broken or the door switch itself. look at the door and see if the latch(actuator) is broken or loose. If not order a door switch. It can be changed easy if you remove the retainer from the bellows and loosen it from the front of machine.
Hope that helps
Nov 26, 2013 | Washing Machines
Light Blinking (start/pause)
Door lock faulty probably,,,,try closing door,,switching on and lightly thumping door near handle
Jun 15, 2013 | Tricity Bendix AW1000W Front Load Washer
Washing machine will not start
we had a very similar problem, our machine is only 12 months old and the filter at the bottom front of the machine has a small fan in it the filter was blocked with a coin blocking the fan from turning after reomoving the coin the fan was able to turn and the machine functioned correctly. hope this helps. tony
Jul 19, 2012 | Tricity Bendix AW1000W Front Load Washer
Hi I have a Tricity Bendix dishwasher model DH090. Light comes on, starts up, tablet even drops out of the holder but then the dial stops, nothing else happens. It doesn't matter which of the four...
My wife discovered the solution to this problem.
If you place large plates at the front then the flap with the cleaning tab can't open. So only place small plates at the front of the Dishwasher.
Oct 03, 2011 | Tricity Bendix 18 in. DH090 Free-standing...
Problem with the machine.
once you have checked the door is shut properly, then i would start with the door interlock, DO NOT test by bypassing this can cause serious damage to the timer, replace if needed and work with safety unplug from power supply before removing any item taking note in detail of any wires etc
Sep 30, 2007 | Tricity Bendix AW1000W Front Load Washer
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Colin Stickland
Colin Stickland
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
