Question about Duraflame 750W/1500W Electric Stove Heater with LED Flame Effect - Black -
I have had my heater for 2 yrs. Now that it has gotten cold I turned it on and it shuts off after 1 min. do I need to replace something or was this product a waste of money?
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
I have a Williams Gas Space Heater Model#3501912. I purchased this furnace about 10 yrs ago. I have noticed that the space heater will not shut itself off. The gas burners are on, but will not shut itself...
I would suspect not. It's very, very rare for a control valve to go bad, unless someone tried to force it to urn with a pair of pliers or something similar.
If you have provided annual service to the heater, it's probably just residual gas remaining in the burners. To test this theory, turn the flames down to low and then turn the burner OFF. Do the burners and the pilot light go out? If it doesn't, you'll be that rare consumer that needs the Control Valve replaced.
Just to help you out a little bit more. I have provided a link to the Owners Manual for your heater. It's in a downloadable, printable, pdf format.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0408171.pdf
Hope this helps. Please let me know.
Rich
Feb 07, 2011 | Williams 3501922 (NG) Gas Compact Heater
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
My Air Conditioner does not get cold after I turned it off and turned it back on. I have now turned the themostat off about 20 mins ago
Air conditioners need a few mins to stabilize (the fluid in the lines) after they are shut off in the middle of operation. The comperssor will normally time out for several mins after it shuts off (or you shut it ofF) preventing it from coming back on within that time. So if you turn it off, and then right back on, you can expect warm air for several mins untill it times out.
Jun 17, 2009 | Honeywell Electronic Programmable...
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Only 3.5 yrs old stops getting cold...
It has a defrost problem.  If the evaporator gets totally frosted up it can't circulate the cold air.  It will be one of 3 things.  I will list by most common.  1.  Defrost thermostat (clips onto the evaporator).  2.  Defrost timer.  3. Defrost heater.  If you have some basic tools and a multimeter I can walk you thru the checkout.  I would need the complete model # from the sticker inside the fridge section.  Let me know if I can help further.
Oct 16, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Duraflame 750W/1500W Electric Stove Heater with LED Flame Effect - Black - Logo
260 people viewed this question
Top Duraflame Event Planning & Celebration Experts
DAVE PARTA
Level 1 Expert
samiya_jahan
Level 1 Expert
Are you a Duraflame Event Planning and Celebration Expert? Answer questions, earn points and help others
