Question about Husqvarna 3200Psi Pressure Washer W/ 270Cc Honda - HVL 9032PW
Inlet hose burst after shutting down high pressure wand
Where is the inlet regulator on my karcher 3300 high pressure washer
no inlet pressure regulator as they work of mains pressure
the only pressure regulator ther eis works off the wand trigger
when the trigger is pulled the pressure in the line drops off and the regulator switches on the motor to produce high pressure
when the trigger is let off the regulator reads the pressure and shuts off the pump;or allows the pressure to by pass back to the inlet side of the pump
Oct 30, 2016 | Karcher Garden
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Brigs and Stratton powerwasher is cloged before the hose leading up to the gun
There is a filter at the inlet where you connect the garden hose. There also may be a filter where the high pressure hose connects to the pump. There also may be a filter where the metal wand connects to the high pressure hose. Check them all.
Jul 01, 2011 | Briggs & Stratton Gas Pressure Washer...
If a washer not used for a few years would that cause any problems
Hi and welcome to FixYa, I am Kelly
The seals do have a tendancy to harden / dry out or... corrosion prevents the unloader bypass valve from moving / operating properly. I recommend you put a little oil (2 oz maybe...) through the unit on purpose via the inlet water connection. Then connect your water hose and force the oil though the unit with the air in the water supply hose while it purges. DO NOT turn the unit on until your sure the water supply hose has purged out all air. Then turn on the unit making sure that you cycle the wand trigger rapidly for a few minutes by cycling the trigger until the high pressure hose is not so rigid then let the high presure hose charge fully again. Cycle trigger wait, cycle trigger wait. 1 second bursts until you get full pressure. Then use normally. This usually wakes up pressure washers that have been resting :)
Thanks for choosing FixYa,
Kelly
Apr 18, 2011 | Karcher Garden
My Karcher 330 M has blown two water inlet ( Garden hose inlet ) elbows. Replaced one and then after about 5 min operation shut off the valve on the wand and immediately the new elbow split the same as the...
I have a larger gas powered karcher, just make sure the water going to your karcher is not obstructed from its path. on mine i bought a goodyear hose that can be purchased at northern tools or any hardware store. and use it just for pressure washing. good luck!
Dec 23, 2010 | Karcher PSI Electric Pressure Washer
Shuts off when high pressure wand is attached
Hi Brian. Welcome to FixYa I am Kelly. This sounds as if the bypass / unloader valve is stuck in place and the pump id dead heading causing the unit to shut off. (There is most likely some corrosion in the unloader / bypassy valve assy / housing. What you can try is pouring at least 3 oz of oil into the water inlet assy and briefly.... like VERY briefly switch the unit on then back off. Then let it sit over night. The next day connect everything for normal use then turn the unit on again briefly. Use a bucket to PURGE the oil that you put through the system by squeezing the wand Power SW Off until the oil purges. Then switch the unit on and rapidly trip the trigger at 0.5 sec intervals or less. If it trips off wait 5 mins and try it again. Do the rapidly tripping the trigger on the wand routine for about 20 seconds. Your forcing the bypass unloader valve to cycle trying to clear out any debris / corrosion.
This works often and well. There are exceptions. Hopefully it will work for you.
Thanks for using FixYa.
Kelly
May 07, 2010 | McCulloch FHH18A Electric Pressure Washer
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda...
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Feb 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
Cannot get it to uptake the bleach for spraying Dewalt pressure washer 3100 psi
On most pressure washers you wont be able to draw soap/bleach into pump unless you are spraying on low pressure.There is a valve on the inside of inlet hose fitting that closes when high back pressure is sensed.Would it draw bleach into hose when wand tip is removed?
Nov 21, 2009 | Dewalt Garden
Poor pressure and water comes out of the detergent hose
replacing the wand wont solve the pressure problems, its going to be the pump problems, pump create high pressure to the wand. hope that help
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
When garden hose is connected to the pressure washer no water comes out of the wand, engine is off.
Dear radcongirl,
Try removing the high pressure hose from the machine. Then connect the water hose and see if water comes out of the outlet.( you can also try this by putting on the machine for a few seconds). If water comes out of the outlet, then you have a problem in the high pressure hose or the wand and trigger. Check also the lance and nozzel for blockage.
I do not know what kind or model of machine you have, but most machines the water always comes out of the outlet when water is fed to the inlet. In bigger machines this cannot happen because they have a reserve tank.
Regards,
Fulltech.
Jul 16, 2009 | Honda Maxus Pressure Washer MX5222
Husqvarna 3200Psi Pressure Washer W/ 270Cc Honda - HVL 9032PW Logo
21 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
