Question about Honda Ex350 350 Generator Service Repair Manual 61zc300e2
Honda ex350 has no ac output - Honda Ex350 350 Generator Service Repair Manual 61zc300e2
    Master:
  • 342 Answers
Could be the avr if it has one brushes on slip rings or capacitor or diodes on aramture
Posted on Nov 04, 2013
2009 Hero Honda Passion Plus charging system
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test:
Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
5. Stator Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity your stator is shorted to ground and must be replaced.
6. Regulator Test:
Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test:
This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Electrical Modification on Hero Honda Passion
How to Test Your Motorcycle Charging System
http://fullmanuals24.com/brand/hero-honda
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Jul 04, 2017 | 2009 Hero Honda Passion Plus
1993 Honda shadow vt 1100 drove it to work today park it for about 2 hours went out to crank it the bike started for a second then died hit starter button again and lost all electrics no electrical power...
Hi, Bobby the following is a comprehensive charging system test that is guaranteed to the find issue with your system.
1. Battery Test: The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test: Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Check Connections/Wires: Inspect the regulator/stator plug, and check the battery terminals for connection/corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Start motorcycle and change Voltmeter to AC volts.
Generic Specs:
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on system, check service manual for specification
Generic Specs:
Stator IB test or Ground Check:
If there is continuity to ground your stator is shorted to ground.
5. Regulator Test: Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Fwd/Reverse Bias Test/Diode Test: This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
VT1100C No power just went dead Honda Shadow Forums Shadow Motorcycle Forum
http://www.jetav8r.com/Vision/Stator/fault_finding_by_www.electrosport.com.pdf
Honda SHADOW VT1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual
Feb 19, 2017 | 1994 Honda VT 1100 C Shadow
2002 Honda VT 1100 C2 Shadow Sabre how to check if your getting power from alternator
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
5. Regulator Test:
Identifying Wires:
Stator test honda shadow
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Jun 27, 2014 | 2002 Honda VT 1100 C2 Shadow Sabre
1994 Honda VF 750 C Magna no battery power
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
5. Regulator Test:
Identifying Wires:
94 magna has no power to anything
Honda Magna VF750C Service Manual
Honda 1995 VF750C Magna Owner Manual
Apr 06, 2014 | 1994 Honda VF 750 C Magna
2005 Honda CG 150 Titan ESD not charging
Hi, Venzgalutera before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
6. Regulator Test:
Identifying Wires:
Battery Charge Lead- Wire going from the regulator to battery positive.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from the regulator body to chassis ground).
For more information about your issue and valuable "FREE" downloads for viewing or printing that you will need please click on the blue links below. Good luck and have a wonderful day.
How to test your motorbike battery with multimeter multimeter tutorial
manual motor honda cg titan 125 pdf Honda Motor Vehicle Manufacturers
Honda CG150 Titan ES Owner Manual
Mar 23, 2014 | 2005 Honda CG 150 Titan ESD
1986 Honda GL 1200 Aspencade Gold Wing not charging
Hi, Arthur before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
5. Regulator Test:
Identifying Wires:
86 GL1200 Asp SEi not charging GL1200 Information Questions goldwingdocs...
Honda GL1200D Shop Manual
Honda GL1200 1986 Owner Manual
Jun 04, 2012 | 1986 Honda GL 1200 Aspencade Gold Wing
1984 Honda Goldwing Gl 1200 not charging
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
5. Regulator Test:
Identifying Wires:
84 GL1200 won charge battery
Feb 05, 2012 | 1984 Honda GL 1200 Aspencade Gold Wing
Honda 2004 Sabre will not charge the battery
Hi, Rhall20448 before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
6. Regulator Test:
Identifying Wires:
Why won my battery hold charge
Honda Shadow VT1100C Charging System Repair
Jul 27, 2010 | 2004 Honda VT 1100 C2 Shadow Sabre
Optoma projector Ex350 connect to xbox360
buy a new projector i recommend sanyo projector specially model XT35... cause your projector is not compatible to your xbox.
Oct 06, 2009 | Optoma EP716 Multimedia Projector
Honda Ex350 350 Generator Service Repair Manual 61zc300e2 Logo
188 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
